Dawelio
Awesomeness
524
440
My understanding is that with cases like the T1 and Meshlicious, the mesh is the filter, rather than having a grid of hole punches and then an additional fine mesh filter.
The thinking is that it reduces cost, side panel thickness, and aids in creating a nice, simple, clean look that multiple layers wouldn't be able to replicate.
What do you mean by that exactly? Could you elaborate on that?
BRSxIgnition
381
544
Somethings happening.
Really hoping this ain't some April Fools joke or something.
robojim
254
222
The gift makes me think a giveaway is scheduled which might be an indicator that things should be in the warehouses soon? A couch I ordered recently finally arrived in the US too 😛
BRSxIgnition
381
544
If I remember right, a user posted about a shipment from Lian Li to Newegg arriving at the Port Of LA recently.
That said, not sure how far off that pins the Meshlicious in terms of finally being available.
Batch 2 is also too far away. I hope they can get another boat or just end up shipping direct to customers.
sunjizzle
Long time lurker, first time poster. Could GPUs taller than 155mm fit if a slimline radiator and slim fans are used in lieu of thicker rad and fans. Say for example the accumulative thickness of the slim setup is 48mm as opposed to 63mm thick for the regular setup (e.g. Arctic Liquid Freezer II)
Recently discovered the GPU I waited several months to receive doesn't fit in my T1 and the meshilicious has caught my eye and I think it can work.
Firebear
35
If we are lucky, the Suez Canal blockage won't delay it any further as it is most likely that the amount of ships going through now will have to queue at the harbours so it will take around 10 weeks until everything is back to normal from what I have heard in the news.
Onus
25
Probably August.
So importing it via NewEgg and MyUS to Germany would be the best Solution to get it till June?
It wouldnt be that expensive and i would have it but does anyone know how big manufacturing issues on the first batch were?
just to know to what % im totally screwed if anything goes wrong
BRSxIgnition
381
544
Nobody but reviewers and influencers have gotten their cases so far. It's all been delayed.
Reactions: futurewau
