Completed Lone Industries L4
raksan
41
55
You'd be spending a lot for the 360 and 160
Regardless it fits. Someone has crammed an internal 200W meanwell in an L4.
I have a passive 400w meanwell in it, but I do have some air flow generate from 2x 80x15mm fan which cool the graphic card. I have very little space for 2.5" ssd though.
Advokatrix
57
40
Hi there,
i am following this topic for quite some time now. Since the L4 is not available anymore, I would try to build something similar myself (using acryl). My plan is using acrylic glue (welding effect) to bond the pieces together and permanently (using extra strong glue) attaching motherboard standoffs to the main back plate.
Unfortunately, it is difficult to get exact measurements of the io-plate/pcie cut outs. Is there any chance to get that data from you?
Sorry for any mistakes (not native speaker)
Cheers
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
Hi there,
Cheers
Everything you need to design your own case is in the resources section. For the IO plate cutout, check out the latest ATX spec.
Reactions: Jello
Advokatrix
57
40
i think there was a misunderstanding. i meant the case panel, where the io is placed including pcie cut outs. dont know how large those pcie cut outs need to be for half hight pcie. there are a ton of drawings for atx full hight pcie slots but none for half hight pcie.
Edit: Nevermind, got what i wanted elsewhere. thanks anyway :)
rcradiator
117
79
