List of SFF Chassis?
Banaffi
I can´t remember any full lists of sff cases. But you could search over at optimum tech´s channel for a brief summarisation of nearly every sff case, if that helps you.
CC Ricers
2,234
2,557
Here's one I made, organized myself and some other list I found on these forums.
The list is somewhat dated, like I gotta add new boutique cases from Velkase and Sliger (as well as Taobao ones) but it displays and filters a lot of information.
khanate
Works great except when entering gpu length or cooler height it always shows 0 items, no results found.
7,741
We used to have a list in the long-dead SFF Wiki. Alas, only a few people helped edit content in said Wiki, so it died a slow death. We've been considering re-launching it, but we'd need some more help from the community :/
CC Ricers
2,234
2,557
Are you entering numbers only? It won't work if you add units like "mm" to it.
Also this requires a max value to be filled in, for both items.
khanate
Yes only numbers, was only entering minimum size, entering a max value made it work, thanks.
