Hi all!
I have checked various chassis like
All of these have unnecessary space. I will fit in a chassi a micro-ATX motherboard with M.2 storage (so tiny it takes no space). There should be a tiny PSU like the HDPlex
https://hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html , this can be fit into the cubical form required by the mATX motherboard.
There should be some big fan too and this will fit into the shape of the cube also. Alas clearly a mATX chassi does not need to be bigger than approx 260x260x80mm.
Browsing the market, I can't find such a chassi anywhere. Who sells it? Do you know anyone who could make a custom order for me?
Thanks!
- "Metalfish G5 MicroATX" 300x300x100mm 2.5kg https://www.aliexpress.com/item/1005003336051704.html
- 柏越科技 (Baiyue) "M99V3" 276x280x135mm https://item.taobao.com/item.htm?id=599945830908
- Streacom FC9 348x289x109mm 4.4kg 11l https://streacom.com/products/fc9-fanless-micro-atx-case/
- In-Win "CJ series" CJ712 CJ708 307x95x290mm 8L https://www.in-win.com/en/computer-chassis/cj-series/
Thanks!
