Lian Li/DAN A4-H2O
Jarmusche
Hi guys, newbie in here and sorry for my English which is not my native language.
Recently i've purchased A4-H2O and i'm going to migrate from NR200P when it arrives. I had planned to buy EK AIO 240 (Basic or D-RGB) because tubing over VRM and PSU looks very clean. But on the flipside, one of the tubes seems very stiff over PSU cord. I thought i would figure this out somehow.
Yesterday i noticed Phanteks Glacier One 240MP. It has brand new pump, silent like EK AIO at %80 pump speed, but it has longer tubes (400mm). And i discovered AIO tubes may go under PSU, i did not know it's possible. Some people say this is the most efficient orientation for AIO tubing for this case.
I have ROG B550-I motherboard, so unlike AORUS boards, there's no obstacle mounting the pump facing I/O side of the board.
EK AIO's are not sale on my country but i've found $87 for used (mint) D-RGB one, Basic model is not even exist. Phanteks is available to buy and pricing around $115 for brand new. Price is not an issue, i'm more into EK AIO than every other AIO's but also willing to build and use the case pain-free.
Will be appreciated for your recommendations.
mopvl
finally finished my build
Specs:
I5 12400k
Asus Rog Strix B660I WIFI
Kingston Fury 2x16gb 5200mhz
Samsung 980 Pro 2TB
Phanteks Glacier One 240mph AIO
Corsair SF750
I can take pictures from the inside if you guys wanna see
what do you think? do you think there's something I can improve?
It's my first build and it was challenging lol
Reactions: Fa5en
Windowstar
Can't find any information on the cpu block height of the Corsair H100 LCD - does anyone know if it will fit into the H2O?
GH247
Anybody using an Asus B550-I? I want to mount a gen 3 m.2 on the backside but am debating whether to squee a heatsink on it. It’s naked now & not touching the case divider but I think adding a heatsink would be a very tight fit.
I have just done an A4-H20 build and it a heatsink will not fit.
I'm looking for some cable length so I can order a custom length PCIE and 24-pin.
hrh_ginsterbusch
139
54
wp-devil.com
Just a quick question about GPU depth - specs say triple slot, but that can still mean a lot of variation. So, whats the max width / depth within the GPU side?
For comparison: Meshlicious all mesh panels has a total depth of 65 mm available (inside; opening is 63ish).
Thanks in advance,
cu, w0lf.
jkiejr
82
31
Edit: hopefully nevermind. Just needed to reseat my CPU.
Hi, what should I do if I am having riser issues. Using a gigabyte x570si v1.1 and a EVGA 3060ti. I had the computer up and running in a different case, switched to the a4h20 and no video.
ScottSimply
118
222
Are you using a 3.0 riser? If so you'll need to switch the PCIe slot to run at gen3 speeds, it's a BIOS setting.
Reactions: riba2233
Synestia
Hello, can anyone confirm that nzxt kraken x53 + aorus b550i pro ax combo will fit in this case?
The cpu block height is right on the Case's max allowable height, and that particular mobo is known to sit a bit higher, so I'm afraid the side panel won't close...
Metroversal
223
489
Will it fit RTX 4xxx series?
this case fits a 3-slot GPU with an length up to 321mm
Here is a first research for the new RTX 40x0 Series. The green labeled cards will fit.
Name Slots Length Height
Asus RTX 4080 12GB ROG Strix 3.15 336 ???
Asus RTX 4080 12GB TUF 3.25 305 ???
Asus RTX 4080 ROG Strix 3,5 357 150
Asus RTX 4080 TUF 3,65 348 152
Asus RTX 4090 ROG Strix 3,5 357 150
Asus RTX 4090 TUF 3,65 348 152
ColorFul RTX 4090 BattleAx 3 326 140
ColorFul RTX 4090 iGame Vulcan 3,25 340 145
Gainward RTX 4080 Phantom 3 ca. 315 ca.137
Gainward RTX 4080 Phoenix 3 ca. 315 ca.137
Gainward RTX 4090 Phantom 3 ca. 315 ca.137
GIGABYTE RTX 4090 AORUS MASTER ca. 4 ca. 350 ca. 160
GIGABYTE RTX 4090 GAMING OC 3.5 ca. 330 ca. 150
GIGABYTE RTX 4090 WINDFORCE ??? ??? ???
INNO3D RTX 4090 iChill X3 3.25 336 146
INNO3D RTX 4090 X3 OC 3 336 145
MSI RTX 4080 12GB Gaming Trio 3 ca. 330 ca 140
MSI RTX 4080 12GB Suprim 3,5 ca. 340 ca. 140
MSI RTX 4080 12GB Ventus X3 2,5 ca. 305 ca. 140
MSI RTX 4080 Gaming Trio 3,25 ca. 330 ca 140
MSI RTX 4080 Suprim 3,75 ca. 340 ca. 140
MSI RTX 4080 Ventus X3 3 ca. 305 ca. 140
MSI RTX 4090 Gaming Trio 3,75 ca. 330 ca 140
MSI RTX 4090 Suprim 3,75 ca. 340 ca. 140
Nvidia RTX 4080 FE 2 305 137
Nvidia RTX 4090 FE 3 305 137
Zotac RTX 4080 AMP Extreme 3,5 355,5 166
Zotac RTX 4080 Trinity 3,5 356 165
Zotac RTX 4090 AMP Extreme 3,5 355,5 166
Zotac RTX 4090 Trinity 3,5 356 165
VR4EVER
youtu.be
Hey guys!
Nvidia 4080 (16 GB) is stated with 3 Slot (61mm).
The H2O case states 3 slot 60mm max - so, do we need to file the metal down or will it be a tight but working fit…?
Thanks!
MarcParis
Apr 1, 2016
3,597
2,676
Hey guys!
Thanks!
well like RTX3090 FE, I would not recommend at all to use any 3 slots passthrough GPU inside Dan A4 H2O. (2 slots maximum)
Reactions: riba2233
Thoth33
Would the ID-Cooling IS-55 fit? The case clearance is 55mm and the cooler height is 55mm, so I am curious if would could be squeezed in.
I just purchased this case from Newegg as they had a deal today where the PCIE 4.0 version was $130.
I wanted this case because I liked the A4 form factor, but I wanted top exhaust. After having a AIO destroy a whole build, I have an aversion to water cooling, so I would appreciate any air cooler recommendations. The IS-55 looks good but I am worried about clearances. Also considering AXP90-X53 and Black Ridge. Going to be cooling a 5700x. Suggestions would be appreciated.
MarcParis
Apr 1, 2016
3,597
2,676
IS-55 could fit, in theory, however no evidence so far (IS-55 is not fitting Sliger SM with same CPU cooler clearance of 55mm). We are within error margin.
However, even if IS-55 fits, it would be like AXP-X53, it will create noise turbulence.
Another solution could be Noctua NH-L9a + 25mm fan + Fan duct NA-FD1.
In any case, you would need to undervolt your cpu (PBO with negative offset) .
Beji
Good morning everyone!
I am building my PC, I tried EK 240 but the tubes are so rigid that I hated... do you have anything else to offer me?
I thought of a Fractal Design S24 or a Phanteks Glacial, something that is simple to install, I have a B550i asus, thank you very much
scatterforce
358
240
A couple of people have tried in this thread with success. They claim less turbulence than an AXP90-x53 with a 90mm fan. Just be careful of your motherboard/ram selection. These will matter.
