Nothing to report yet sorry, I'll post something in here as soon as there is"BUMP"![]()
Yeah regular atx.
This sounds like a crazy idea but why don't you make the smallest possible design that'll fit an atx mobo with full size psu?
Plus once the case starts getting into the 15 litre + zone there are already some really good cases serving this market such as the Chimera Industries Cerberus X.
And to cover the cost of developing a new case would be greater still.The Cerberus X costs almost £400 after shipping and import duty to the UK!!
This is what Overclockers UK have been asking me to do ever since the LZ7 launched! I've just not been able to personally get onboard with the idea, I think it will result in a very space in-efficient design unfortunately. Plus once the case starts getting into the 15 litre + zone there are already some really good cases serving this market such as the Chimera Industries Cerberus X.
Yeah, maybe not a full size PSU (SFX is good enough this days), but ATX motherboard compatibility would allow you to sell tenfold your current amount of cases.
This is very promising!Quick update - sorry for the delay with the results for the XTD competition, I've not forgotten. I'm thinking it may just be better to offer a prototype with the final design changes rather than an outdated older version.
Good news is that I've implemented the changes I wanted to make and today a prototype has been made which will be tested over the next week or so. More information on the testing will follow.
The first step went well and everything fit together perfectly, cable management was a little tricky trying to figure out the best order to install everything but I was happy with the final result. A build guide will be included in the user manual which should help to smoothen out the process for future builders.
Some quick phone snaps of the prototype ready for testing, strictly no fun will be had while testing games on this machine
The test system includes an i7-8700k with an EVGA GTX 1080Ti SC and Corsair SF450 SFX PSU. The CPU is cooled by a Noctua NH-U9S with rear 92mm exhaust and a slim 140mm Side intake fan.
Initial testing is giving me CPU temps of 64C and Motherboard temps of 31C during Prime95 12 thread max heat test with fan speeds under 1000rpm, the system still sounds like its idle, absolutely mental.
Unigine Valley @ 1080p max settings is running the GPU at 66C with a GPU fan speed of 1519 rpm, this is audible from across the room but only faintly. The GPU is the loudest part of the system it seems, but at 66C under load there is quite a bit of thermal headroom which should allow me to play with the fan curves and reduce system noise whilst gaming.
Looks clean, but I really liked those laser etched panels with Lazer3D logo you posted earlier. Will they be optional in your customiser?
Also will there be anti-vandal button version panel?
Thanks! Yes I hope to have both plain and etched panels available, although the etched panels will carry a price premium due to the laser etching time. All current corners, front, rear and HDD panels will be compatible. The XTD panels will replace just the Base, Top, Left and Right panels.
These are the materials I am considering to make available for the side/top/base panels:
If anyone has any material requests not mentioned above let me know and I'll add it to the list for consideration.
- Clear Gloss (plain)
- Smoked Gloss (plain)
- Clear Gloss (Half Etched)
- Smoked Gloss (Half Etched)
- Black Matte
- Grey Matte
- White Matte
The top panel will be available in both standard vent (slots along the edge above GPU) and full XL-Vent (fully ventilated - shown in the photos above).
Both the Vandal switch and Full IO options will be available, although I'm not sure every material type will be available for both IO options, I'll need to talk it through with Overclockers.
Both of the etched, and the three matte options are exciting to me... plain is nice too. I guess I love them all! Based on your experience, which surface finish will hold up the best in the long run (scuffs / scratches / etc), especially with multiple builds / tinkering?Thanks! Yes I hope to have both plain and etched panels available, although the etched panels will carry a price premium due to the laser etching time. All current corners, front, rear and HDD panels will be compatible. The XTD panels will replace just the Base, Top, Left and Right panels.
- Black Matte
- Grey Matte
- White Matte
Will this new design have a removable flap at the base panel for quick M.2 slot and CPU cooler bracket access?
Thanks for the insights on the different finishes. I look forward to more updates!In terms of resistance to actual scratching that damages the surface, then they are both the same as they are made from the same material. Although I would say that the matte finish can mask the scratch slightly, and light scuffs can sometimes be buffed out or reduced with a fine/soft cloth. The gloss finish is a bit less forgiving.
