If anyone is curious a RTX 2080Ti can in the standard case, with a small caveat
Yes, I am patiently waiting. Unfortunately my PSlate Custom MB cable does not work with my new SF600 for some unknown reason. So I am now using the stock 24pin cable until I can work out why. I sent him an email about it today. (So that is what I am really waiting for right now!)Ha ha! I guess your waiting for the XTD panels then?!
The only concern I have about waiting is for the end of March. I'm hoping Brexit doesn't make deliveries to mainland Europe difficult. But otherwise it doesn't both me so much, extra airflow is always nice!
Thanks again for your quick response, we can continue emailing each other since its now OTSent you an email reply as well, but this is due to the 24 pin not having the sense (double) wires on it. You can get away without them on Silverstone and the SF Gold PSUs, but the SF Platinum needs these to be stable. No problem sending you a replacement though, just send me a reply confirming your address!
Nice offer to the community, but unfortunately my 2080Ti is 269.69!
I'm looking forwards to how the final design will look and what panel options will be available.
Which brand/model of 2080 Ti do you have?
Hey guys,
I had a sample XTD case ready to send out to @Tek Everything for him to look at (sorry for the delay Jay!), but I have tweaked the power supply mounting design (to route the power cable internally) since making this sample and didn't want to send him an out of date case. This version has the power cable exiting the case under the base panel.
So, I was thinking it might be a good idea to offer this sample case to you guys at a reduced price of £50 + shipping to your country (usually around £20 for Europe or £35 rest of world). It's a full case with all the parts required to construct a full case, including the angled power cable and Vandal power button. This case is also backwards compatible with the LZ7 (vandal power switch version) for anyone who already owns one. The main panels are grey with a set of smoked/etched top and sides and a second set of plain matte black top and side panels.
This is the configuration of the case on offer (case only included):
As there may be a few of you who are interested, please can you post below a short description of the system you would build into the case if you were to receive it. I will give you till Monday 28th Jan 13:00 GMT to post your build descriptions, after which I will open it up to a vote to decide who gets the case. A condition of purchasing this case would be to post your build and feedback (with photos) into this thread, I hope that seems fair?
Some quick size specs / restrictions of the case to help plan your build:
- GPU - Up to 269mm in length, 131mm in height (with 10mm recessed PCIe power connector, e.g. Gigabyte GTX 1070 ITX just fits height wise). Tested with EVGA GTX 1080Ti SC Black Edition (touches front panel but fits ok) and NVidia RTX 2080 Founders Edition.
- CPU - Up to 135mm in height (compact tower cooler is ideal such as Noctua NH-U9S)
- Case Fans - 1x 140/120mm slim fan (side), 1x 92x25mm fan (rear).
- Storage - 2x 2.5" drives
- AIO compatibility - 1x 120mm or 140mm AIO mounted to top panel above main motherboard area
- Top Panel - Extra fans can be mounted to the top panel up to 140mm x 25mm.
I’m planning on picking up a Radeon VII next month, would that fit? I’m not even sure what the dinensions of the card are if i’m honest...
Great, thank you! According to those specs it should fit.Double post.......
What are the dimensions of the test case?
My GIgabyte RTX 2070 is 279mm, there is not even a remote chance, isn't it? it looks really great, good job K888D.226mm Width, 158mm Height (not including feet), 280mm Depth.
