Just throwing this here in case anyone wants to 3d print out this case. I spent a weekend designing a 3d printed ITX case a while back. It's fully finished and can be printed/assembled. I want to give credit where it's due: This case was inspired by Lazer3d LZ7 and Fractal Design's Node 304. It uses m3 screws and m3 inserts. You need a soldering iron to melt the threaded inserts into the slots.
Some highlights
- GPU max size: dual slot 185 mm length (186.78 to be exact)
- CPU max cooler height: roughly 70 mm (might be a little less)
- Storage: 2 x 2.5 in 7mm SSD
- SFX or SFX-L power supply (max length 186 mm)
- Overall dimensions (L x W x H - 234.26mm x 194.78mm x 149mm)
I test fitted all the components at one point before I sold it off and everything fits correctly.
If anyone's in interested I'll upload STEP files you to modify.
Some highlights
