I don't think this case will be able to implement that feature, it would need to be baked into the design from the ground up with some kind of dual layer for the base.
Is this something you would be implementing in the future alterations?
Not for the LZ7 or XTD, but perhaps future new cases. For instance the CG7 has this feature as the bottom panel can be removed whilst the motherboard is installed. But for the LZ7 it would need some fundamental design changes which isn't possible at this stage.Is this something you would be implementing in the future alterations?
Hey guys, sorry for the lack of updates on this, progress is still being made.
I've spent a bit of time with this as my main PC and played a few games on it, I still can't get my head around how quiet this thing is when gaming thanks mainly to the Noctua U9S exhausting directly out the case, it's been a real pleasure to use.
Here are a few more photos of the latest prototype to give you a bit more of an idea of how the internal layout looks, it would look much better with some custom cables.
I'm using the Noctua fans from the U9S in another build and so instead I am using 2x 92mm Fractal Design fans which actually match this colour scheme quite nicely:
And a couple more outer shots showing the contrast between the matte Grey and Black pieces with the smoked gloss sides:![]()
You can also see that the power cable is now routed inside the case compared to the first protoype which routed the power cable externally:
Thanks!Looks really neat. Will there be enough vertical space for a huge top-down cooler like Noctua C14S and Bequiet Dark Rock TF?
Thanks!
CPU clearance is limited to 135mm height and within the boundary of the ITX board.
The Dark Rock TF is 112mm tall so will be fine in that regard, but it's quite a wide cooler and so you may see issues with it hanging over the edge of the motherboard and fouling on the side fan or PSU.
The Noctua C14S will fit height wise with the fan installed under the fins making it 115mm, but again it's a big cooler so you will need to make sure it stays above the motherboard and doesn't hang over the edge. This can vary between motherboard due to a variable socket position.
Love the new look is that a triple card slot I see in the rear?
I look forward to seeing this being released (if at all?). Any timeline?
Just 2 slots, I don't think I would release an ITX case that is triple slotted!
I would estimate it will be released around the middle of the year, sorry I can't be more concrete than that.
Is the case strictly 2-slot? My RX580 Nitro+ is 3mm over the 2-slot limit.
Any plan to test some top-down cooler (e.g. 131mm Dark Rock TF)? I am worried that the PSU and CPU cooler will be fighting for air.
There is about 3mm gap between the EVGA GTX 1080 Ti SC and the side panel, I would advise to stick to purely standard thickness 2 slot cards, mainly to ensure compatibility, but secondly if the fans are right up against the side vents you will get increased fan turbulence noise and reduced thermal performance.
The original prototype was tested with a Silverstone NT06 PRO with an RGB Akasa fan installed on top, the performance with the 8700K was very good, but the Noctua U9S is better.
I think either style of cooler will give you plenty of thermal headroom to install some real high end CPU's with room for Overclocking if wanted.
The Noctua U9S is giving me temps of 64C with 12 thread Prime95 load for the 8700K at stock settings.
I think I need to hire you as my own personal ego inflator! Thanks for the comments!I was humbled to be invited to have a look at and give some thoughts on that first prototype, @K888D has forgotten to mention here that we had the 8700k in that rig in the pics running on a low volts 5ghz all core. It's seriously impressive !!!
He's a decent engineer, not just a brilliant case designer!
The thermals on his cases are one of his top priorities, this sets him leaps and bounds above his competitors !!!
Hi, I was wondering if there is any updates on this project since mid-March, Im very interested in upgrading but the majority of mini-ITX cases I've seen are not very attractive compared to this amazing design.
Thank you!Hi, I was wondering if there is any updates on this project since mid-March, Im very interested in upgrading but the majority of mini-ITX cases I've seen are not very attractive compared to this amazing design.
