Here are the features of the Case:
Putting up together the different parts of the case is the same as the formdt1 in which you have to assemble the actual body of the case first before putting in the components inside.
Inspired by Formd T1 and based of the model of Dan Case a4.
Smallest case possible that supports dual 92mm radiator for better cpu cooling.
Perforated panels for maximum airflow and aesthetic.
Push pin locking mechanism for ease of removal and quick access and installation.
Travel pc - Because of its size, it aims to provide ease for those who needs their PC on the go. Just put it in your hardcase, and you’re good to go.
Bays:
-1x2.5 inches ssd/hdd
Fans:
-2x92mm fans
Radiator support:
-1x92mm radiator
-1x84mm radiator
Hardware clearance:
-Itx motherboard
-Flex atx psu
-270mm max gpu length
-47mm max cpu cooler height
Size:
-Dimension:273x114x223mm
-Volume: 6.9 liters
Please leave a comment and/or suggestions below. I am all ears for the improvement of my work. Thank you!
