Just finished a hybrid Ryzen 2700X and VEGA 64 Mini Beast
hyp36rmax
43
60
Just finished my quick build with a Streacom BC1 Mini test bench. The core parts were actually going into an Ncase M1 build, but due to an issue when leak testing with a compression tester. I ended up transferring the core parts onto the test bench instead.
I'm actually digging this now lol.
  • Streacom BC1 Mini Test Bench
  • AMD Ryzen 2700X
  • AMD VEGA 64 Limited Edition
  • ASUS X470i STRIX ITX
  • GSkill 16GB DDR4 3200Mhz CL14
  • Samsung 970 500GB NVME M.2
  • Samsung 960 500GB SSD
  • Seagate 2TB SSHD Firecuda
  • Noctua NHD15 Air Cooler
  • Noctua NF-A12x25 PWM 120mm Fans
  • EK VEGA GPU Waterblock
  • Hardware Labs Nemesis 240 GTX Radiator
  • AlphaCool Laind DDC
  • Bitspower Reservoir Top
  • Silverstone SX800-LTI PSU
  • Ensourced Custom Sleeved Cables
tinyitx
2,279
2,338
Pretty build.
Could you describe the power button construction in some details? Thanks.
hyp36rmax
43
60
Pretty build.
Wow. That is awesome!
I’m curious about the power button as well.
Thanks!!!
I ordered the power button from Amazon: https://www.amazon.com/gp/product/B01MT3277L/?tag=theminutiae-20
The Power button mount from Openbenchtable.com / Thingiverse: https://openbenchtable.com/community/ | https://openbenchtable.com/community/3d-print-16mm-push-button-holder/
tinyitx
2,279
2,338
Any chance of reporting your ambient/idle/gaming temp of the M.2 SSD?
I am much curious to know, on a BC1 mini test bench, the thermal performance. There should be minimal airflow over the SSD location, as most air will flow through the NH-D15 fans.
MarcParis
Apr 1, 2016
3,629
2,722
Nice build..:)
What is its volume?
My only concern is cat & dust compliance...:)
Anyway i’m sure your setup is pretty quiet. Are you experiencing any coil whine on rx vega 64?
Reactions: hyp36rmax
jtd871
1,166
851
Minor amplification to the parts list (and product links since it took me a bit of effort to find these parts):
Alphacool Laing DDC10 pump, https://www.alphacool.com/shop/pump...ool-laing-ddc310-single-edition-black?c=20559
Bitspower DDC Mini Water Tank Plus reservoir, (fits on DDC pump) https://www.bitspower.com.tw/index.php?main_page=product_info&cPath=283_285&products_id=53
The (very porous) sponge is included with the reservoir. From what I've googled, it supposedly helps with controlling bubbles in the res and helps with bleeding air from the loop.
Duality92
307
330
The sponge also helps prevent cyclones in the res, thus sucking in air in the pump and pushing it through your loop.
When I first saw you had a D15, I must admit I was skeptical, but you pulled it off fantastically! Good job! :)
Onimashou
26
I am in the final stages of doing a similar build any reason you went with an air cooler for the CPU instead of just adding a block?
hyp36rmax
43
60
Nice build..:)
What is its volume?
Thanks! I'll measure the volume later this afternoon. Yes this setup is silent enough for my standards, even when fans are at 100%. No coil wine on the VEGA 64.
Reactions: MarcParis
bananaboy93
112
