UPDATE:
Renders of the current version (45% finished):
List of changes:
- Size: This is now a 17.3 inch machine! So the width got reduced by 30 mm and depth by 20 mm which means less volume. To make this possible the inner layout had to be changed (pictures will follow when model is ready). The main reason for 17.3 inch is the availability of way better panels. This gives access to the following panels:
1) 17.3 inch WQHD (2560x1440) 120 Hz TN 400 cd (my favorite)
2) 17.3 inch Full HD (1920x1080) 144 Hz IPS
3) 17.3 inch 4K (3840x2160) 60 Hz 100% Adobe RGB IPS
- Keyboard: The case got optimized for Mircosofts Surface keyboard which fits perfectly.
- Sound: The new layout gives me the opportunity to integrate 3 inch speakers with 30 - 50 Watt RMS in the corners. This means way better and more powerful stereo sound. A powerfull little stereo amplifier board will power these speakers.
- Cooling: Cooling system and airflow got improved: 3 x 70 mm fans (backside), 1 x 90 mm fan (above mainboard), 1 x 60 mm fan (side). No speakers on the front means better air-intake and better evacuation of hot GPU air.
Specifications:
Dimension base unit: (H x W x D) 425 X 360 X 45 / 80 mm
Volume base unit: 9 liter
Material: Aluminium and stainless steel
Display: 17,3 inch WQHD 120 Hz
Mainboard: ITX
Graphics card: 2 slots, 275 mm length, 125 mm depth with AiO CPU cooling installed
Power supply: SFX PSU
Hard drives: 2 x 2.5 inch
Side ports: 2 x USB 3.0
Cooling:
- 120 mm AIO with slim fan
- Fans: 3 x 70 mm, 1 x 120 mm, 1 x 60 mm
List of changes:
Specifications:
Mainboard: ITX
Cooling:
