If the HDPLEX is placed above the motherboard, may be. With the current arrangement, I believe the height of the case needs to be >200mm since HDPLEX 250W has a height of 25mm.Dropping the PSU at 40mm would presumably make the case 181 x 181 x 100 or 3.3L no?
Good to hear ! A SATA cable with a latch should fix the issue, unless with "SATA port" you mean the physical port on the device that's soldered to the PCB.
Whoops I mean the SATA cable's connector into the SSD. It does have a latch, but it seems like the SSD side doesn't have any ledge for the latch to snap into.
Does this mean that realistically we're looking more at a 2017 Q1 delivery?Short Update: Running into a snag in the scaling of manufacturing the case. The current fab is having a hard time forming the XS consistently. I'm working with my current fab and looking for other fabs to see how I can resolve this ASAP.
About the PSU, i was wondering why you chose to orient it so that the side with the labelling faces up. I got my own FSP400-60FGGBA and i removed the non-label side by unscrewing 4 screws. I don't ever hear the 40mm spin up anymore (6700k 4.5ghz and gtx1070). If you flipped the PSU orientation you could just remove the side instead of drilling holes into it (voiding warranty) and I reckon airflow from the cpu fan would be enough for the 40mm not to spin up.
It's because there is, in fact, an unofficial standard orientation for FlexATX PSUs, based on the manufacturers' choice of which way the additional bracket is installed in the front (fan-side in the picture below)
Note that in the above picture, at the end of the fan-side of the PSU there is an additional bracket that secures the PSU on a different axis. That bracket is only usable when the PSU is orientated where the power connector is on the left side when viewed from the back.
Of all the bracket installations I've seen, it is consistently in this orientation.
