Power Supply HDPlex 400W AC-DC Adapter
LFO
100
23
Thats what Larry said 50 pcs it's been put back loads.. I've been emailing asking for the last year now! But it's finally here just pre-ordered so hope I get one of the 50 as they won't even ship till 25th Feb.
Thanks for the info I'm going to have to looking into something with less soldering as I'm no good with that
Shipping from Germany has been delayed again to March the 5th... some more waiting I guess...
fishyswaz
Haha, yeah, I know, there was a time in the 90's when I MacGyver'd a Super Famicom back to life with only my teeth, some wire and sticky tape until I was back home to fix it properly.
Cable strippers are definitley the way forward, but for someone just wanting to solder three wires, shelling out for cable strippers isn't too cost effective (then again, neither is dental work lol).
Reactions: HYPERTiZ
lawney
104
68
After watching the last live stream it makes me wonder if there is enough room left for the pins sticking out of the GX16-3 connector as it looks very tight to fit the 400W ACDC in mini IMHO.
So is there a list of GPUs that fit in the S4 Mini w/the new 400ACDC?
CARC Mini
169
48
sure :
a) for side mounting, any GPU with height 116mm or less.
or
b) for front mounting, any GPU with length 170mm or less. [ you'll need to mod your interior frame ]
and there are modified SkyReach cases on ebay.
Elerek
228
165
sure :
or
For front mounting you can't use the hdplex 400 dc, right? Have to use the KMKPT dynamo combo?
CARC Mini
169
48
correct.
Dynamo 360 is 120mm, while HDPLEX 400W AC-DC is 198mm.
120mm + 198mm = 318mm, which fits in SkyReach.
if you go 23mm or more over, then it won't.
HDPLEX DC-DC is way over.
Penguin
40
You could front mount the AC-DC and put the DC-ATX where the AC-DC normally would go (bottom/next to the power inlet to the case) with some modding. Cable hell will ensue but that should be workable.
jkmuskego
CARC Mini
169
48
Anyone have any idea if the new zotac 1660 ti super compact, will fit in NFC skyreach with the 400ac-dc? looks like the height should be fine with a few mm to spare.
https://www.newegg.com/Product/Product.aspx?Item=N82E16814500462&Description=1660 zotac&cm_re=1660_zotac-_-14-500-462-_-Product
111.2mm (h) x 145mm (l)
https://www.ebay.com/itm/8-Sleeved-...YxK-n:sc:USPSFirstClass!40526!US!-1:rk:2:pf:0
yes, it will.
and if you want to fit a GPU in the front instead, along with a HDPLEX 400W AC-DC, you can get a modified SkyReach case from ebay.
rockwentzy
Hi guys, I'm planning to build a new PC for a friend using the s4 mini and currently waiting for the HDPLEX 400w ac-dc dx-atx to arrive. I'm planning to fit the HDPLEX inside the s4 mini. My question is, what options do I have when it comes to the GPU selection? From what I understood from this thread, a gigabyte 1080 mini will fit. What other GPUs can I go for?
sparklepony
71
I believe the 1660ti should fit right in.
Once the PSU arrives I'll let you know if the zotac 2060 fits. I think it won't exactly fit but I think it should be quite simple to make it fit.
akisu
111
65
Should be possible with the Inno3D 2070 Twin X2, custom GPU cables and HDPlex 400 AC DC/DC Combo.
Maybe it's also possible with the Gigabyte 2070 Mini ITX, HDPlex 400 AC DC and Dynamo 360 (Both in the front). But you have to modify the HDPlex because it's 1mm to tall.
