Power Supply HDPlex 400W AC-DC Adapter
Nanook
805
793
@Josh | NFC This makes a lot of sense as an external brick, but how would this work inside an S4M? The fastest card you can get that is standard height and not too long is the Galax 1070 which is impossible to find in the US. So other than that, your talking about 1060 builds. This seems like overkill for that sort of thing, or am i missing something?
400w would be good for an i9-7980XE + GTX1060 (Peaks being 250w + 150w).
Probably also good to not run the PSUs at max capacity, right?
Cooling that i9 is another story...
KMPKT
3,382
5,936
Larry has okayed me to share a few more things so here goes:
Width is being narrowed to 57mm for this release which means it should fit inside the front panel of the the S4M. This will of course provide ample space for overheight cards such as the Gigabyte 1080 ITX.
HDPLEX 800w????
Yep. Larry has been working on this for a while. Basically you can use two of the new 400W AC-DC units to power this bad boy.
Also where I think this thing will really shine is that it is being engineered to handle momentary spikes of up to 520W. PLEASE do not confuse this as meaning you can run the unit with a power budget of 520W, but instead that hardware that tends to spike a little more violently (ie. R9 Nano) would be able to be run within a 400W power budget and have some headroom to run.
AMv8-1day
228
193
So as much as everyone wants to focus on the obvious pairing with the amazing S4M, and seriously @Kmpkt , thanks a lot for the direct collaboration with @Josh | NFC, but what about other applications in the SFF space? We've got this great budding SFF marketplace with SFFLAB, Chimera Industries, etc. lets get some more collabs going!
With the 800W DC-ATX in particular, it feels like we are stepping farther and farther out of the reasonable realm of the S4M and more into SFX-less Project Orthrus, Cerberus, or Mach One territory.
@LukeD @PlayfulPhoenix Any thoughts on this? Possible bracket/placement R&D efforts in the near future?
Reactions: TheHig
TheHig
951
1,171
Exactly. This psu looks very promising for any number of sff applications and is looking like a tremendous step forward in the sff psu space.
Good stuff.
Reactions: br3nd0
Untero
83
80
Here's a video of the unit running a Furmark/Prime95 dual stress pulling upwards of 350W:
Also will be shipping with a C7 compatible and has extremely low current leakage at 0.16A (I believe this means shock risk is virtually nil but perhaps @Thehack could clarify.
Ho boi, can't put into words how excited I am, f5'ing this thread for almost 4 months and here it goes.
I really hope to take one at the trip to gamescom, but I understand chances are it could easily be postponed to later times.
News about narrowing unit down are also amazing.
smitty2k1
978
501
Man with all these power supply developments going on right now I feel like we need to create a Wiki to cover them all... SFX, SFX-L, TFX, Flex-ATX, AC-DC 12v, AC-DC 19v, internal bricks, external bricks, DC-ATX plug in boards, HDPlex, GUnique, PicoPSU, KMPKT Dynamo... the list goes on.
I'm so confused.
Reactions: MurphyLyfe
Thehack
Creator
Mar 6, 2016
2,818
3,674
J-hackcompany.com
For standard "safe equipment" is 500uA. That is 0.0005A.
However this is a stringent requirement for hospital level systems. For consumer class systems it depends on your local requirements, but anymore than a few mA is bad.
Add on: I would check your test set up and if there's something wrong with it as 0.16A is unusually high.
Reactions: aquelito
Jotunn
28
My main question is overheight GPU support in an S4M. Will this fit with a ZOTAC 1070 mini or will I need to use a Gigabyte single fan model to fit?
Reactions: Josh | NFC
Biowarejak
Maker of Awesome | User 1615
1,744
2,262
None of the diagrams show an overheight card with an internal brick, but I will take your word for it and keep a dremel handy.
Pretty sure he didn't mean with one, though I could be mistaken. Take a look at the other high end builds in the forum and see how they pulled it off :)
Jotunn
28
That's what I figured. There is some breathing room in between since my current build has an EVGA 1050 ti, which has a nameplate on the top edge, which uses up that space, so it will be interesting to play with once this AC-DC converter comes out.
Josh | NFC
Not From Concentrate
NFC Systems
Jun 12, 2015
1,869
4,468
www.nfc-systems.com
Yeah my bad ; I resolve to stop answering notification alerts without reading the thread for contex. Sorry!
You can't fit a Zotac mini with an HDPLEX 400 AC-DC (internally) no matter how much dremeling you do. :(
veganzombiez
27
29
Darn, doesn't seem like the AC-DC internal will fit in the front If I get the Gigabyte 1080 mini, and replace the fan/shroud with x2 fans via Skybracket duo. Maybe a 120 + Skybracket? Hrm...
Sean Crees
352
316
I'm in the process of making an accessory for this, and i just want to make sure i have the right dimensions. Final dimensions will be 57x40x180mm?
smitty2k1
978
501
I was just looking at the specs for this and the drawings on the HDPlex site show a polarized C8 connector. However, C8 connectors are not polarized as part of the IEC 60320 standard, although they do seem commonly available.
I'm trying to source a C8 polarized panel mount, but I can't seem to find one. The power cords themselves seem easy enough to source. In the USA if it matters.
Thehack
Creator
Mar 6, 2016
2,818
3,674
J-hackcompany.com
It is because the polarized one is C6. Search for C6 Power Entry.
