Form factor doesn't matter to me, its the only x300 board that I've seen so far that supports non-APUs. Plus, since it's ASRock, swapping UEFI modules should not be as hard.
If form factor doesn't matter I'm curious: which advantage does a X300 motherboard have compared to e.g. A520?
For example:
ASRock A520M-ITX/ac
Supports AMD AM4 Socket Ryzen™ 3000, 3000 G-Series, 4000 G-Series, 5000 and 5000 G-Series Desktop Processors; Supports DDR4 4733+ (OC); 1 x PCIe 3.0 x16; Graphics Output: DisplayPort, HDMI; 7.1 CH HD Audio (Realtek ALC887/897 Audio Codec); 4 x SATA3, 1 x Ultra M.2 (PCIe Gen3x4 & SATA3); 6 x USB...www.asrock.com
Others in this thread care more about the form factor, as well as the single 19V input rail. For me to get non-APU CPU support on the A300W/X300W Deskmini, need an X300/A300 board that supports those CPUs- it doesn't matter to me if the board was EATX. Hopefully I'll be able to transplant that CPU support into the A300W/X300W UEFI Firmware.If form factor doesn't matter I'm curious: which advantage does a X300 motherboard have compared to e.g. A520?
For example:
ASRock A520M-ITX/ac
Yes, however there are hardware differences between the X300 and A300- I'm running an A300W with the X300W bios and I still can't overclock.Doesn't X300 allow for CPU/iGPU overclocking ?
That would be nice to know. There's a guy on youtube with a 5700g and an A300 and X300, but he didn't test the CPU with those motherboards. Try asking:
smallformfactor.net
- Supports AMD AM4 Socket Ryzen™ 5000/4000/3000/2000 Series Desktop APU & CPU (up to 105W)
- 1 x DisplayPort, 1 x HDMI, 1 x D-Sub (Integrated)
- 500W power supply with custom length cables
- Supports PCIe Cards (Max. Length ≦ 20cm)
And again, you can re-buy the RAM -.-, since Max is using U-DIMMs. Not pleased by this fact.
Yea, you totally got the point. It's about the upgrade-perspective.What's the issue with the U-DIMM ? It's just regular desktop DIMMs. Unless it's from an upgrade from "old" Deskmini to Deskmini MAX perspective (and the need for new RAM).
One question, how come you have more "Reactions" to your posts than the actual number of posts?!
nice nice hehe
I was back to this topic the other day...I can manually enter frequencies for the CPU and GPU, but they don't actually do anything. It looks like the chip ignores anything out of spec.
Also, my logic analyzer came in and works great. I was able to tap into my hardware SPI flasher's interaction while reading the bios:
I'm waiting for some more stuff from amazon this afternoon, then I can decode the interaction between the activator chip and the CPU.
