Motherboard [08/12/2024]ASRock DeskMini A/X300 BIOS /"P2.00.SL01"(Curve Optimizer & S3 support) & "P2.10" for X300 - AGESA ComboV2 PI "1.2.0.Cc"
Dr. Nick
56
45
In the P1.90 bios, is there any cpu core voltage offset option (negative) in order to lower the temp a bit?
Besides Curve Optimizer I don't think so. You can lower the PPT manually though, which won't cost much performance, especially if you add 200 MHz via Boost Overdrive.
Reactions: obrida
obrida
What kind of RAM is that, and what settings do you use? I've Crucial 3200 CL22 RAM running fine with 5600G.
I think there's an option to save the BIOS options to FAT32 USB stick, first menu if you scroll all the way down?
Crucial Ballistix BL2K16G32C16S4B 3200 MHz (16GB x2). Settings via XMP profile.
I exported the BIOS and tried to use a dump tool to and convert it to text but wasn't successful.
Dr. Nick
56
45
You could try to manually increase timings (CL etc), lower the speed to e.g. 3000 MHz, and/or manually increase voltage (I'm not sure if it possible to go over 1.35V though). XMP RAM is always tricky, can work, but you can't be sure. Is this particular set on the supported list?
Reactions: obrida
yck3110
34
I am using 2x16GB) 3200MT/s CL22-22-52 1.20V (G.SKILL Ripjaws F4-3200C2D-32GRS), only enable xmp 3200mhz at 1.35V, do you have any tips on overclocking the ram a bit, to gain a lettle performance?
Dr. Nick
56
45
Does that RAM have any XMP profile in its SPD ROM? Couldn't find any info regarding that on the G.SKILL homepage, thus it doesn't seem so. You can try to increase voltage to 1.35V and then lower settings for tCL, tRASCAS, tRASPrecharge, tRAS and tRC, and run RAM stability tests. I haven't tried this, I prefer my Deskmini cool and quiet. ;)
yck3110
34
the ram only got one xmp profile of 1.35V 3200mhz-16-18-18-36,
could i just keep increase the 3200 mhz setting without touching tCL, tRASCAS, tRASPrecharge, tRAS and tRC until the system unstable?
Dr. Nick
56
45
You mean just increasing the frequency, but leaving timings at the JEDEC specification of e.g. CL22? Could work with higher voltage. I'm not sure what would be the benefit of that, the lower CL setting at 3200 should help to increase performance, then again, what do you need it for anyway? Games? Running RAM beyond its specification always comes with risks of instabilities.
yck3110
34
It is possible to just swap 5600g to 5700g, without reinstall windows or bios , currently on deskmini x300 with bios p1.90,
does 5700g recognizable in bios p1.90, as i just swap to 5700g ,it would not even get into the bios ,
Or do i need to update to the latest bios before swapping to 5700g
  • Haha
Reactions: HydrAxx747
yck3110
34
  • Haha
Dr. Nick
56
45
5700G is supported by P1.90, it could be required to re-activate Windows. Be sure to follow the required steps if you use Bitlocker.
yck3110
34
After i swap to 5700g ,it cant even boot into bios or windows, just stuck at a black screen and i try to the press F2
to enter bios and etc.
But it doesn't response no matter whay keys i press,
i dont know if it is a compatible issue of the bios or what,
or do you think the CPU is a defect
or i just missed some step?
does it required to update to the latest BIOS?
Dr. Nick
56
45
5700G is supported since BIOS 1.70. If it shows you the Press F2/Del to enter BIOS message, the CPU should be up and running. Did you try to clear CMOS/unplug the battery?
yck3110
34
I have tried clear CMOS/unplug the battery and also use different keyboard while putting one the 5700g,no matter what method i try , it just cannot get into the bios. but once i have swap back to 5600g, everyrthing become normal back.
I dont have another am4 motherboard to test the 5700g, this only the only thing i didnt try yet.
I think i should the return and refund the 5700g, just too frustrated to fix the issue maybe giving up to upgrade
Wasmachineman_NL
I'm on P2.00.SL01 and it breaks PBO settings 💀 if you want to get the most out of your 5700G, stick with 1.80 because that's the BIOS where PBO etc still work.
HydrAxx747
195
227
Hi, you shouldn't complain to me about this, I am not the one who edits, patches or updates BIOS, I only share what the ASRock BIOS department sends me, nothing else, if you have any problems (even minor ones) do not hesitate to report them to the following email address while briefly specifying your configuration used (deskmini model, CPU, RAM at least, and OS if it is a software problem): support@asrock.nl
It is literally their job to fix problems so if people only complain on private forums or reddits, then they cannot fix problems they are not aware of, they are not fortune tellers😅.
Wasmachineman_NL
Hi, this is not me who should be complaining about this, I am not the one who edits, patches or updates BIOS, I only share what the ASRock BIOS department sends me, nothing else, if you have any problems (even minor ones) do not hesitate to report them to the following email address while briefly specifying your configuration used (deskmini model, CPU, RAM at least, and OS if it is a software problem): support@asrock.nl
Done.
PeterSFF
27/10/2024: Added new Beta-BIOS "P1.91", changes: Add Curved Optimizer Option for the Supported CPU.
14/11/2024: Added new Final-BIOS "P2.00" and new Test-BIOS "P2.00.SL01", a variant of "P2.00" Final-BIOS with S3 Sleep Support.
I'd like to get copies of Beta-BIOS "P1.91" and new Test-BIOS "P2.00.SL01", however the Shared Folder on UploadNow only says "This folder does not contain any files." Do I need to pay for an account there to make the files visible? TIA...
HydrAxx747
195
227
No account needed, I reuploaded the BIOS files:
Reactions: PeterSFF
