Motherboard Group Buy/Crowdfunded Modded BIOS for the Asrock A300m (Deskmini A300)
dimtsef
so i will have soon the 4650G ! what is the latest beta bios guys ?? i have already the 360N and 360R the N is about 1mb bigger file as far as i can see .
Feynek
Good evening,
I bought Crucial Ballistix BL2K8G32C16S4B 3200 MHz but in "cpuz" it says 2666 despite the XMP enabled in the bios (3.70).
In the bios and windows it is indicated 3200mhz, it is a bug of "CpuZ"?
Do I have anything more to do in the bios other than activate the XMP?
L’image contient peut-être : texte qui dit ’หอาก oc Tweaker OC OCTweeker1DRAMInformation Tweaker Information XMP xdvanced X1001 #1 #2 3200 1.35 16 H/W Honitor 18 18 36 72 560/416/256 Security ty Boot 0 Crucial BL8G32C16S4B. M8FE Description Descr Manufacture Part Number Module Size Bandwidth PC4-21333 (1333 MHz) Rank 1 DRAM Manufacture Micron Week/Year 46/20 Module Type DDR4 Serial Number E39B82AA DRAM Stepping 00 SPD Ext. 20 Getdetails via OR code’
L’image contient peut-être : texte qui dit ’0Kbits/s RadeonRX5 Radeon 60secondes Compositione a memoire Utilisée (compressée) 2,4Go (0 Mo) Disponible Vitesse: 13,5 Go Emplacements utilisés Facteur deforme: Matériel réservé: Mise cache 955 Mo 3200 MHz de2 SODIMM 65 Mo Validée 4,3/32,9 Go Réserve paginée 185 Mo Pool paginé 280 Mo étails Ouvrir| Moniteur de essource Spécifications de Windows’
Aucune description de photo disponible.
yuusou
109
67
I believe you mean the 2400G?
There's always the 3400G, the 4650G or the 4750G, but you don't seem entirely comfortable with this, so I'd recommend you stick with your 2400G or at most upgrade to the 3400G.
Feynek
yeah sorry it's a 2400U ^^
"There's always the 3400G, the 4650G or the 4750G, but you don't seem entirely comfortable with this" what do you mean by that?
yuusou
109
67
You were struggling to realize whether your RAM was configured properly. The 4650G and 4750G requires a beta BIOS and have stability issues with RAM speeds requiring quite a bit of tinkering. They can also on occasion draw more power than that the little power brick is rated for. With all that in mind, I wouldn't recommend going beyond the 3400G on your A300.
Reactions: gustav and Feynek
gustav
193
90
Good evening,
Hello, I have experienced similar behavior on tight timings. It was reporting in cpu-z 1500MHz which is ×2 = 3000MHz, had in the BIOS 3200MHz instead thou.
I described a bit of it here:
Reactions: Feynek
Feynek
salut! =)
Ah okay i understand. It's that complicated to configure with this kind of apu? in reality it does not matter as long as I have someone to guide me in the setting because i've never "oc" =p
For consumption, I do not know what had the basic barbone but it is a psu of 400w in 6pin with an "amp" (?) That we see on the video glued/stuck to the rig. Shouldn't it?
sorry for my poor english, i need to use google translate some time.
Feynek
hm we see nothing, i cropped the picture, it's sharper suddenly ^^
ps: sorry for multipost... dont hit me! ='D
