Motherboard Group Buy/Crowdfunded Modded BIOS for the Asrock A300m (Deskmini A300)
Danlopez1222
63
101
@Danlopez1222 I was wondering if those pins near the ram were actually connected. Thanks, for the heads up. And that's the site that came up when I did a search. I'll probably grab the pro as well.
Regarding the software for flashing, which do you prefer?
They make their own drivers and software in house- it's what I've always used. It should be available on their downloads page.
Reactions: GLSRacer
GLSRacer
80
58
Awesome, thanks again for the quick responses. I don't have a 5700G on hand but I'll keep an eye out for sales.
Aelda
@Danlopez1222
That sounds very interesting for the A300. I also have a 2400G installed in mine and have not yet decided what to upgrade with.
Have you done a stress test of the 5700G in the A300 to make sure that the processor really runs without problems and there are no bluescreens under load ?
Danlopez1222
63
101
@Danlopez1222
I applied liquid metal and ran CPU-Z's internal stress test to see how low temperatures are. I've been getting consistent 4.4-4.6 Ghz on all cores under load, with temperatures in the 70s. It looks like GPU performance has been knocked down due to the inability to overclock RAM, since the default is 2400Mhz with loose timings. My Vega 11 on my 2400G with 3400Mhz RAM seems to get higher scores on 3d Mark.
Reactions: GLSRacer
Aelda
Maybe the problem with the ram clock is not a problem with the X300 bios, but that the A300 does not provide enough power. I think that was discussed here in the forum with the 4700G processor, that the ram clock could not go over 2600Mhz, because the A300 provides too little power.
Danlopez1222
63
101
I don't think its that, because I cant even change timings at 2400MHz ram. Its almost as if it's ignoring all bios settings.
W4RR10R
211
211
The pinout is in this thread, somewhere closer to the beginning.
GLSRacer
80
58
With recent announcements of support for Ryzen 5000 on 300 series boards, I wonder what the chance is that ASRock will do right by their customers and provide a BIOS to support the CPUs on the A300?
xxTech
I got mail:
Hello,
Sorry, the information I have is, that Cezanne is not be supported on our DeskMini A300.
Also no information yet f there will be newer AGESA codes for this mainboard.
Best regards,
GLSRacer
80
58
Figures, they keep trying to pretend like the X300 has something newer than the A300 as far as actual board compatibility
xxTech
Unsatisfying answer:
Hello,
also for Renoir I have to say sorry. I do not have closer information yet if it will be supported with future BIOS.
So far, only these CPU’s are supported and tested:
best regards,
msystems
661
1,169
@Danlopez1222 about the idea of CPU-microcode/-support transplantation:
I think we are a step further to be able to achieve that. There is a product announced: "DeskMini Max" which is 5000-Series based
mainboard with PCIe 16x slot. Therefore, we could probably grab it's BIOS/UEFI and do some surgery on it combined with A300 UEFI :)
DeskMini Max is using *no* dedicated chipset. Still running on knoll-based-config.
It seems from the video (they're opening up the case, so you can see the mainboard) they've updated the power-stages on the mainboard being
4+1+1 (I guess '4' to be able to satisfy 105Watt against 65W using '3' VRMs)
This platform seems to be indeed the A300 v2.0 because of the PSU, but also TDP being up to 105 Watt it seems they've updated the VRMs and
power-rails for the CPU/SoC/APU - there is residing my hope of "true" o/c being actually feasible. There is only one M.2 slot for NVMe's though and 2x S-ATA.
And being 10L in volume, it remains a question weather a standard mITX/ITX-platform would be actually the "way-to-go"-platform, since 10L is not small factor
anymore - when comparing against 1.92L from the A300. I think the price will be the point, on which a customer can decide.
PSU + Case + Mainboard (B550-based) => ~300€
Deskmini Max therefore should be <300€
And again, you can re-buy the RAM -.-, since Max is using U-DIMMs. Not pleased by this fact.
It took a while, but this product finally came out as the "Deskmeet" and indeed has no chipset, but does not limit the bios to apu processors. In case anyone would pursue this idea again.
W4RR10R
211
211
Unfortunately the deskmeet doesn't solve my old problem. I needed a smaller than itx board specifically mstx like the deskminis, the deskmeet is bigger its deep itx.
Fortunately, I no longer have my problem as my pc setup goals have changed and I've already started working on it.
