Motherboard GIGABYTE AB350N-Gaming WIFI
Boil
1,253
1,094
Gigabyte seems to have a habit of unfortunate connector placement...
I seem to recall that the previous few generations of ITX motherboards have had the USB header plopped right in between the rear i/o / PCIe slot / CPU keep out zone...
cadiguno
128
116
Gigabyte tends to be more expensive than it should be where I live. I thought that meant I'm going to miss out on the best ITX AM4 board. But looking at the connectors that doesn't seem to be the case. Will be pretty happy with ASRock's.
T_Tank
137
113
blegh blegh blegh those 24pin an 8pin locations that wifi adapter placement.... wtf... why is the usb headers and sata on the top of the board edge of the board to o_O
Also... is the cpu socket offest or is that just all the odd port placemetns messing with my eyes?
Reactions: Soul_Est
4,783
It's closer to the front edge of the board than you typically see but otherwise the socket placement isn't all that offset.
Reactions: Soul_Est
Mackan
309
161
Yeah, and I made very clear to the reps that I was not happy with the connector layout and would like to see it improved in future boards.
If they could put the CPU 8 pin where the USB 3.0 internal header is (and dump the usb header), I think the overall layout would be quite nice for some itx cases.
4,783
We did discuss the possibility of a community driven revision via a crowdfunding campaign or something.
But something like moving the 8-pin connector is non-trivial and the MOQ is pretty steep.
Reactions: NATi and Biowarejak
Pelican
66
65
I'm disappointed by the lack of optical audio. I like being able to connect my PC to our home theatre system sometimes. Maybe they don't expect there to be a demand for Ryzen media PCs.
Those ASRock boards are going to be hard to get a hold of...
Reactions: Twinstar
Rabarbersaft
Having the 24pin + Sata ports on the top like that will benefit me. Other then that i prefer AsRocks board. But I think Ill get my first ever gigabyte board. Finally my 1700 have somewhere to be.
Mallot
41
24
I don't understand why you're all so upset with the 8pin and 24pin.
The 24pin really makes no difference, the only time it'd make an impact is if you're building in a s4 mini or similar, due to how limited you are with the hdplex psus.
It would make more sense to switch position between usb3 and 8pin though. Considering how long even SFX cables are, reaching to the 8pin won't be a problem at all.
For me specifically, the offset CPU socket means I won't have to cut out even more on my case, for the CPU fan to fit. Now I'll just have to space it a bit with vibration dampeners, to make the airflow a bit better. Really, my only complaint about this board is the red accents, but even that is kept much more subtle than on the ASRock board.
8pin is a bit weird, but it's whatever to me. Tiny bit worried about clearance of that wifi thing, but I assume it's no taller than standard ram.
Reactions: Rabarbersaft
4,783
On cases where the chassis is right up against the top of the motherboard that 24-pin will be a pain to unplug.
Mackan
309
161
I've stayed away from Gigabyte boards due to their poor fan control in UEFI. Something to look out for. Perhaps they have improved.
Reactions: fminus
4,783
I believe the latest gen Intel boards from them have full PWM, but I haven't checked on the AMD side.
GentlemanShark
Asus RMA sucks
Marsupial Computing
Dec 22, 2016
358
148
Is there a run down of all the Realtec CODECs? I'm struggling to compare them all without memorizing a whole bunch of numbers with limited data.
Arboreal
818
814
Yes, the SG05 (unlike some other cases) will benefit from the ATX 24 and SATA ports being on the side to maximise front to back airflow from the intake fan
freshislandcoconuts
I was wondering if anyone had any experience using the Corsair 380t with a layout like Gigabyte's, where a lot of the plugs are on the top of the board? It doesn't look like it would fit with how the Corsair is set up (laying horizontal/flat...especially if you have something like a Cryorig H7 or something). Asrock's ITX board might be the only one worth looking in to for people who are using the 380t.
carbonitetoast
29
36
Posted on reddit (https://www.reddit.com/r/sffpc/comments/6ifbl5/gigabyte_ab350n_gaming_wifi/):
