Prototype G-UNIQ ACDC, 7.7-8.5L Expandable Console Case
br3nd0
307
297
Any updates on this project?
Might get a quicker response on gury's discord if you're not already part of that channel. He has posted numerous pics in the chat, looking good though :) I'm not sure if it's the exact same one as he was talking about in this thread, but he looks to be offering a basic case included with each PSU order from what I could gather :thumb:
Reactions: loader963
IronLegacy45
42
25
Any apparent ideas for the release date? Plus is there any way you can put a rad in it after having a full length gpu(about 270mm)?
Wyd4
196
218
I would imagine, if it fits a 3 slot GPU and you are using a single slot gpu water block, you MIGHT be able to squeze a rad over/under the GPU with slim fans and slim rad, but I highly doubt it would be "supported"
AstroWan
33
Where can you get the power brick???
Do you mean where the power brick is? If that's your question, I believe from some of the original post I read that it had two options, if you opted to do a mini-itx motherboard, you could fit an SFX psu, but if you wanted ATX, wahaha was looking into a thin plated power supply that mounted on the skeleton of the case and doubled as hard drive holders. I need to double check to make sure I didn't misunderstand the original post but it was really a beautiful design.
Necere
NCASE
3,281
Pretty sure the large PCB the drives are mounted to is just a power/data distribution board, and doesn't do any power conversion itself. You'll still need an AC-DC brick for that.
Reactions: AstroWan and Elerek
Elerek
228
165
Looks like it adds a bunch of caps, which might help with stability if you're pushing clocks/voltages (probably for pushing lower voltages, this is sff after all), but still absolutely needs a ac-dc brick.
Reactions: AstroWan
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Update 2019-04-14: I got bit by the CNC bug, making this case via Extrusion and CNC.
Extrusion and CNC will give the most versatility for 2-3 sizes for this project. Thanks to an early backer, we should have enough MOQ to hit the same target price.
The following is Prototype 1 = design is not finalized, just testing thermals. I'm waiting for the Sidearmd T1 to finalized before starting this.
chyll2
431
362
Will this be a one off run or it will be on a cycle run?
I am like both this and T1 but can only afford one.
Wahaha360
a.k.a W360
SFFLAB
NCASE
SSUPD
2,131
10,697
Until I finalize the design, it's hard to nail down all the costs and process, so it's just too early to say.
Tazpr
553
429
What is the maximum supported 140mm radiator+fan supported if an ITX length GPU is used?
I like console style cases but there seems to be limited options for the smaller ones to allow for decent CPU cooling...
