Update 2019-08-25: PSU prototype received.
Update 2019-04-14: I got bit by the CNC bug, making this case via Extrusion and CNC.
Extrusion and CNC will give the most versatility for 2-3 sizes for this project. Thanks to an early backer, we should have enough MOQ to hit the same target price.
The following is Prototype 1 = design is not finalized, just testing thermals. I'm waiting for the Sidearmd T1 to finalized before starting this.
Background Story:
Met G-UNIQ guryhwa in mid 2017 and he showed me some power supply ideas. I am not an engineer, but the custom PSU kit looks just awesome - I wanted to put a better casing around his PSU creations. After many late night conversations, set backs, delays, interference, we are finally ready for prototype.
Here are some pictures of the G-UNIQ power kit inside an earlier prototype case:
Product highlights:
Comes in Anodized Silver and Anodized Black, WITH Window and NO Window variants.
The G-UNIQ Custom Power Supply kit looks awesome. it would be a crime not to have a window
Supports *two 120x15mm fans for intake by default. The Top Panel can lift to support *two 120x25mm fans, for high performance setups.
Rear I/O Chassis comes in 2 variants, supporting two different ways of mounting GPU.
3 PCIe slots for G-UNIQ special upgrade kits (will reveal later).
Supports ATX Motherboard with G-UNIQ Power Supply.
Supports Mini-ITX Motherboards with SFX Power Supply.
Dimensions: 72x308x346mm / 7.7L standard, Top Panel lifts to 80x308x346mm / 8.5L for *two 120x25mm fans
Motherboard: Mini-ITX, ATX (require G-UNIQ Passive Power Supply).
GPU: up to 300mm, 3 PCIe Slot thick.
Cooling: 58mm CPU cooler, 140 AIO (short GPU or external power brick).
Drive Support: Up to 3 2.5" drives.
Power Supply: SFX or G-UNIQ Power Supply
Special thanks:
Necere for case layout and the ~7L console-style case thread.
Josh | NFC for collaboration on Skyreach 4 Mini, exchanging ideas on GPU flip bracket.
guryhwa for the power supply kit.
Background Story:
Product highlights:
Special thanks:
