Then you loose the 2.5" HDD support.
That's the dilemma.
Is there space between the PSU and gpu to just put some double sided tape and stick the drive there?
That's the dilemma.
Nice! I had a feeling in my gut there would be other rads that fit just fine.Well, the "feeling lucky" build is still on track! And, if you want to know, NO BULGE! (If you see any, is an optical illusion, like in the first page the pictures with the LT240!)
Removing ALL the rubber pad from the noctua fan, you get 1,5mm off, + the 27mm radiator, well, there are only 0,5mm of difference compared to the LT240 Build!.
Today is a good day...
The LT240 only comes in the LT240 kit. So essentially unless you purchase the AIO you cannot get the LT240. I have a Kelin T12 (fractal rebrand) which I will need a 240mm rad for. So I others trying different rad configs is a big help.With 27mm there is only space for two 15mm fans, correct? No one 15mm and one 25mm? What is the upside of this specific radiator compared to the LT240 one?
Which sounds really awesome! Sorry for asking again, but would a 25mm thick fan and a 15mm thick fan be possible in this configuration? Already bought the 25mm thick one![]()
Working on the manual, just been busy with virus sideaffects.
Use the white / clear rubber pad, attach it to the T frame, this will support the Side Mesh Panels.
Wonderful, thank you!Just use double sided tape, it’s very tight, so you don’t even need to use Fan Bracket.
Using double sided tape means no need to worry about fan bracket spacing for 240mm radiators.
Getting close...!!
You can see I've managed to add the Alphacool DC-LT 40 Reservoir+Pump (fill ports) and thanks to a T fitting, I've put a passthrough thermal sensor that can work as a drain port!
This specific configuration was possible keeping the structure in 2 slots GPU configuration but moving the PSU closer to the panel thanks to the included standoff.
So I could clear the space to have the Pump combo aligned with the radiator port.
Getting close...!!
I can't say that any of them are too thin or too thick, but LT240 is thicker than NVMe SDD on the backside on the mobo, unlike the noctua mounting; you also need to keep in mind that riser goes there, so you'll have gpu -> riser -> ssd/cooler mount -> mobo, and if cooler mount is thicker than sdd that's become the issueThis concerns me; I'm looking at a Corsair h55 and a Sapphire Nitro+ 5700 xt. Is the LT240 mount especially thick that this becomes a problem? Or is the secufirm2 especially thin?
Same stress test I did in the Ghost: the temps ARE AMAZING!
Only 2/3 degrees higher than the Ghost, but that was using the phenomenal Noctua A12x25!
Without FurMark the CPU stay at 76 degrees MAX, exactly the same than in the Ghost. ?
So the GPU in the loop, under stress, is adding 4 degrees to the CPU.
(My system is also running above a radiator, so I am pretty sure the system can run less hotter on a normal desk!)
The pump speed goes from 80% to 100% relative to the Water Temp.
The fans are in the Standard Bios setup.
This system is SUPER QUIET!
Well, mainly because in my build there is no space for it!Why didnt‘t you use the A12x25? ?
Also super excited to build your loop for my machine!
Am I seeing correctly 1455Mhz on GPU on the stress test? Isn't this a bit low?Same stress test I did in the Ghost: the temps ARE AMAZING!
What exactly is preventing you to use it? Don't get me wrong, I don't want to sound condescending, just want to understand all the possibilitiesWell, mainly because in my build there is no space for it!
I've also used the bracket to secure the radiator, and I wanted to have matching fans!![]()
Ah OK, for some reason I was expecting around 2Ghz from 2080ti
