As this thread has a lot of activity and I'm not sure you have the time to check every post, would you rather we send you the shipping suggestions elsewhere?
@Wahaha360 How much clearance is there between the motherboard and the GPU? Are backplated GPUs likely to cause problems?
I'll start with the only negative I have for the whole experience, and that goes to the user manual. The second iteration is much more informative than the first one, but I ended up using a combination of both, plus Ali's build video for anything I had questions on. I think specifying which screws are for what would be greatly beneficial. Including each instruction in an album instead of separate links would be nice as well.
If I had any concerns about anything, it would be the bottom front section of the mesh not having any support to keep it from bowing into the case. This might be a nonissue once I put parts in the case, but I don't see how that will fix what I'm talking about.
I really wish I had known about those screws before I bought the Eisbaer. How could a cooling company put mixed metals in their entirely custom OEM AIO.
I have the @pslate one for the Ghost, and they are perfect! Just the CPU one should be 2cm longer, IMO.+1 for the custom cables from pslate.
More people seemed to have received their packages. Excited for this! ?
Wait for the Distro-Plate, I had the same idea for integrating the DDC into the Distro-Plate.
11mm, it should be fine for GPU backplates less than 3mm thick, most are.
I will love it! Actually if the front structure was flipped, so the wider space on he GPU side, will have way more space!Wait for the Distro-Plate, I had the same idea for integrating the DDC into the Distro-Plate.
Well, the "feeling lucky" build is still on track! And, if you want to know, NO BULGE! (If you see any, is an optical illusion, like in the first page the pictures with the LT240!)
Removing ALL the rubber pad from the noctua fan, you get 1,5mm off, + the 27mm radiator, well, there are only 0,5mm of difference compared to the LT240 Build!.
Today is a good day...
For me personally that's an acceptable dilemma. I use an NVME with my new build and no SSD. Again, for me it'd be an okay tradeoff if I had to choose between a distroplate/buying an NVME or no distroplate but SSD. But I see the problem for people who don't have the possibility to use a NVME.Then you loose the 2.5" HDD support.
That's the dilemma.
It's still 16 FPI so good for the slim fan. but it has a ticker core, so, maybe, better temps? And you can buy it alone, and it's matching my EKWB Waterblocks!With 27mm there is only space for two 15mm fans, correct? No one 15mm and one 25mm? What is the upside of this specific radiator compared to the LT240 one?
It's still 16 FPI so good for the slim fan. but as a ticker core, so, maybe, better temps? And you can buy it alone, and it's matching my EKWB Waterblocks!![]()
