About the Alphacool 1U ES, IF the SSD bracket was a bit wider flipping it ALREADY allows to mount it inside the case!I have to get these
I have to get these
@fabio for the antenna, do you have to buy two modules or do they come in a set?
I'm not sure whether they ship internationally, but mouser.com and digikey.com have these antennas in stock. About $10 USD each, bought individually.
YES, will be better, so it will be possible for sure pushing the pump till the front panel and who want can slide the radiator and add a 25mm fan.![]()
fabio , can you add 25mm thick fan in the front with this setup? DC-LT looks to be in the way.
You think I should cut the T Frame / Chassis so you can move the DC-LT pump forward, touching the Front Lid? This should allow 25mm thick fans in the front.
That would be me, so please make this happen thank you very much pleasure doing business with youYES, will be better, so it will be possible for sure pushing the pump till the front panel and who want can slide the radiator and add a 25mm fan.
Yes!@fabio need your help. For the alphacool ddc310, there was one blue wire for rpm monitoring and two wires for molex power. To use my Mobo fan header, I can just wire the three together empty - blue - yellow - black?
Also, would doing so give me the ability to control pump via DC through bios?
Thanks!
What happened to this forum website? The top now says xenforo and everything looks different.
