    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
hetvler
204
153
sorry if i missed something... didn't want to read through the 80 pages of forum. Is the problem just clearance for the height of the rad? In that case, I could just use a 12mm fan from scythe or something else that is thinner than 15mm, right?
Its ok, we can't all be obsessively checking for updates on the case - happy to help.
I can't answer that one. I'm not sure where the interference comes from with other rads.
but more importantly... I didn't know scythe had 12mm fans. I'm totally buying a Morpheus 2 and seeing if I can fit that sucker in here.
edit: found 2 on ebay. ordering friday. this is the best day ever.
Reactions: PBJ
PBJ
358
546
For example the XSPC TX240 is 20.5mm thick, while the rad on the LT240 is 25mm thick. Even so, the TX240 does not fit because of the width. Since we don't have exact case measurements, we need to compare it to the LT240 which is 270 x 120 x 25 mm (LT240 fits with 25mm fan below PSU and 15mm fan below motherboard). So it may be possible to get away with a 27.5mm rad and 12mm fan depending on the other measurements.
Reactions: DrHudacris
blorkborkey
I am really hoping I can get away with that, just ordered the water cooling parts and almost had an "oh sh*t" moment because I found out the rad was 27.5mm instead of 25.
PBJ
358
546
I suspect length is not a problem. My biggest concern is if it’s wider than 120mm.
schn1tt3r
152
247
The 240LT fits ONLY with the slim fan already, so no, nothing else is supported. If you look at the pictures, you'll see the one regular + one slim fan setup with the LT240 already.
blorkborkey
yes, with a normal slim fan, but with the one which I linked from earlier which is 3mm thinner than the normal 15mm slim fan, it should actually provide 0.5mm more clearance when using it with a 27.5mm rad
MattyKHZ
72
21
Understand two tone will only come after black is sorted, but I’d the I/O PCB sorted now and so only anodising to contend with?
Also is it worth checking no similar issues with two tone anodising at same time to get that headache out the way?
Ophiuchus
Love this case, one probably dumb question however. On the off chance a future batch uses a ventilated, non-mesh panel -would you think they'd be modular additions to this first batch in place of the mesh?
Aviswa
44
66
Is the two tone going to be black and silver or space gray and silver? I thought it was going to be the latter, but the website says “black and silver”
