What you mean?
For the "Default" AMD 3950X, in the BIOS I have the VCORE set to NORMAL (NOT AUTO), RAM at 3600MHz and, and PBO DISABLED.
To be able to TWEAK the Power Limit, you have to ENABLE the PBO in BIOS and then in Ryzen Master I set the Power Limit.
For the OC, I use the Manual OC in Ryzen Master and Setup the Core Speed and the Voltage there.
For the ECO mode, I just activate it inside the BIOS.
Hi
@fabio, I was going to put the "default" settings in the spreadsheet, until I realised it was unnecessary. I've never owned a Ryzen system, and it's a looooong time since I've built an AMD system. A lot of the terminology is new to me. Clearly, I have some research to do!
Anyway, on with the latest spreadsheet. Just to note, I am using one of the default conditional formatting settings in Excel to produce the colour range. For all component temperatures EXCEPT for the CPU, all combinations are included in a single colour range for that component. For the CPU temperatures, the ECO mode, PBO 120W, and PBO 130W tests were given a different colour range from the rest of the CPU temperatures because those three temperatures are so much lower than the rest. Including all of them in a single colour range produced skewed results.
MEASURED TEMPERATURES
DELTA TEMPERATURES (Component Temperature - Ambient Temperature)
Unsurprisingly, the ECO mode produces the lowest CPU temperatures. It also results in the lowest GPU, VRM, and chipset temperatures. However, it doesn't beat the SSD temps of the default CPU, exhaust/exhaust combination. The two PBO alterations aren't increasing component temperatures by much (other than the VRMs), but result in much lower CPU temperatures when compared to the default setting. Clearly, a little tweaking does wonders for system temps. What is the difference in performance?
