    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Van0
129
166
I got an aqua computer Quadro in my build and it runs off a USB header and has 4 temp sensors and 4 fan headers. Other option is to use motherboard temp sensor (a lot of ASUS boards have this). And finally a low tech option is something like this. But yeah, at that point you just have to set the speed of the fan fixed so it's high enough to keep load temps under the danger threshold or have some sort of manual fan control.
That's a cool little unit and given that I won't be using the internal USB header any longer in the new build, I could definitely go this way too. So just hook up the sensor, 2 fans and the USB header provides power as well as data? Or is the molex connector also needed for power? Then just set a curve with the software based on coolant temp and that's it yeah? Where would be the best place to mount it in the case do you think using double sided tape?
Reactions: DrHudacris
DrHudacris
918
1,720
The Molex is needed, for the fans I think. Double sided tape or Velcro will work. But yes, you download aquasuite and set up the fans to respond as you like. It's my first time using aquasuite but it's a great piece of software, and that's coming from someone that prefers BIOS level settings!
Van0
129
166
Thanks for all the advice. I’ve gone this far, I may as well go all in! So I’ll add the temp gauge and fan controller to the build as well ?
fabio
1,885
4,325
The bitspower fitting, which one is that and what purpose does it serve?
This is a good question!
There is no indication anywhere! I hope is a sort of inlet?? I will use it to fill the system.
There is some pictures where that port is used to connect to Magic Cube in serie, bit I don’t know what doesn’t it mean flow wise.
I will keep you here updated!!
gwertheim
938
1,555
If possible I'd be interested to see how it compares to the DC-LT 40 res and if it's easier or more complicated to put together
Reactions: thelaughingman
fabio
1,885
4,325
fabio
1,885
4,325
Ok, so for BitsPower that port is an additional INLET! Good to know! Let's try to fill the system, I hope nothing will flow out! ?
Reactions: aexeq
pyroxide
29
26
What made you change your mind?
I really like the T1 design, but I have to follow my heart. With so much demand for this case, I don't want to have one around if it's not what I want anymore.
I've been lurking this thread pretty much all year. since like a day or 2 before the initial Optimum Tech video.. So much time has passed since then that I am having trouble keeping my mind made up on what to do with it, now that I preordered. More cases are on the market now or about to begin taking preorders. The T1, using an all-inclusive setup with LT240 and an air-cooled 3080/ti would be much a more straightforward project than what I really want to do.
I've been toying with the idea of external pump/res/rad and the Velka 5/7 was suggested. The reason for me wanting to do this is simple enough: I want endgame cooling without having to do something so very different every time I want to upgrade.
gwertheim
938
1,555
Makes sense, whatever works for you. After all, you know what you need or want. Just make sure you send that email to @Wahaha360. I told him to expect it.
