    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
Stinkybear
98
91
2020-04-24 Update: Can't keep up with so many new posts. Created r/FormD - upvoting and downvoting feature will helps us prioritize response to questions and issues
This is meant to help ease congestion on this forum thread, not replace it.
Still working on the subreddit, will open to public when we are ready.
I think you're a mind reader because I was just trying to find this on reddit and found it didn't exist.
Reactions: Truth
gteixeira
23
So updates and surveys will still be posted on this thread?
threestripevida
277
466
I did contact EK about this, but they said they won't be making a monoblock for other (ITX) X570 boards unfortunately.
Maybe they'd consider it, if more people reach out :)
They've made blocks for the non ITX Aorus Master, Aorus Elite and Strix-E.
I've also accumulated some insights over time and will look into it if it's of any added value. Need to check first if you haven't added it already :)
The more info the better! Send me a PM and we can work on adding some more stuff to the document.
threestripevida
277
466
I think I am finally done with the useful links document (except for formatting). I tried making sure I gave credit to everyone that has posted a build log in the thread. There is a lot of stuff in this thread. If I missed anything or something needs to be removed then please let me know. It is a lot of links and I highly recommend that you read a page or two after some of the posts linked as there is some good posts after the one I linked.
@Wahaha360 feel free to post this on the sidebar of the new subreddit.
UnitScott
30
34
Hi y'all!
Pretty new to forums and still just an intermediate builder... but man!, this case has convinced me to get my feet wet (in more ways than one... oh yes, time to confront water cooling again - my arch nemesis)
Google Doc above is incredible btw... those builds have me salivating already...
P.S.: Any chance the T1 won't be able to fit some of the upcoming RTX 3000 series though? Or does the 3 slot configuration eliminate that possibility? Anyways, guess they have to announce those cards first... :/
Reactions: DrHudacris
MisterJester
27
Here are some close up shots. As you can see, I routed the tubes under the psu, 1 to the left of the plugs, 1 to the right, and then squeezed between the psu and front of the case. This way there’s only 2 bends and easy to place and remove.
Tubing I used was: Tygon R3400 - 8MM ID - 11.2MM OD - Black
How long of a tubing run is this?
hprantis
28
48
Hi y'all!
I don’t see FE/AIB 4 slot cards coming to GPUs for a while, if ever, considering they will be powered by more efficient nodes.
deepsheet
Can't seem to find the dimension and weight of the packaging of T1. Does anyone have the measurement and weight with it?
Reactions: Truth
Truth
Formerly TutorialIsland
Mar 19, 2020
90
46
I'm also curious to know if there's any plans for the prior mentioned carrying case, because my sling bag for instance is only designed to carry an ipad pro 11 plus some smaller items, so the T1 is like 3 inches too long. For carry on, especially with a 240 aio such as mine will have, I just want to make sure it will be safe during transport, and this seemed the best solution.
gwertheim
938
1,555
Reactions: Truth
Truth
Mar 19, 2020
90
46
Hmm, thank you for showing me this! Wasn't aware sadly, but I will admit I had imagined something more industrial and compact such as the case, rather than a full scale backpack, I will probably need to make my own small form factor carrying box that is only for the case and maybe a keyboard with some minimal wires.
gwertheim
938
1,555
Do your thing, whatever works for you
Reactions: Truth
