And it's "cheap"! 40EUR in EU.
The AquaSuite software is included for every compatible accessories with an USB internal connection. So, if you buy also a Flow Meter with an integrated USB controller, the software is included with free upgrades for a period based on the class of the device bought.
After, IF you want to keep the upgrading service, you pay 9 EUR one year, 15 for 2 years, Or buy another device. But the version you had before the expiration of your upgrade service, is for life, so, it's not a big deal if it's working ? .
BTWm here you can find the sensors, flow, pressure, temp, etc.
Sensoren
shop.aquacomputer.de
I have the last of the list, an "Flow sensor high flow G1/4 for aquaero, aquastream XT ultra and poweradjust" + the "Flow 3 PIN cable that is not included.
I've chosen this because I had the QUADRO so I can connect them, but of course you can buy also only the Flow Sensor with the USB connection.It's the same
BTW, here you can see how can be compact the system even with a 40mm rad (the only sticking out part is the flow connector).
Under AIDA stressing both GPU and CPU for 60 minutes I got only 10 degrees of DELTA between the coolant and the ambient temperature, MAX 77 degree for the CPU and 47 degrees for the GPU.
So eager to try the XE!!
