    Votes: 116 24.6%
    Votes: 356 75.4%
  • Total voters
    472
DhruvK
I will talk to @Wahaha360 and if I am in error? I will add that option and tag you in a post.
I understand if being added under "USA-other" is a special consideration for the guys who have been posting here since earlier on, but I appreciate this being looked into as well. Sadly I only discovered this community after the OptimumTech video but I've been a long-time lurker on r/sffpc over at Reddit. Just been information gathering prior to plunging in on an ITX build of my own.
stellarwind
If you're considering using a Corsair 120 mm AIO you can cut the tubes the cooler comes with by default, and then replace them with a customised length of vinyl tubing.
I replaced the tubes on my Corsair H105 (eBay - $50 AUD, including two fans) with vinyl tubing; shortened the overall length of my tubes by around 40%, which helped a lot with being able to get minimal clearance between the radiator/fans and my CPU.
Edit: People are taking this test shipping application process way too seriously. This will not be the only opportunity to own a T1. Be patient. Life goes on, case or no case.
PBJ
358
546
I get what you mean and of course I agree that it’s just a case. I think I’ve been pretty patient, but its not really about the case, it’s about clearing up who’s qualified and who’s not. It’s a legitimate question asked respectfully and bearing no ill will to all involved in the Test Shipping process
If anything, I’m grateful to all involved that some of us in this community are getting this chance at all.
forestpatrol
31
48
It fits nicely in 3 slot mode and 2 slot mode.
It is the recommended AIO for most people.
Awesome. Thank you both.
Reactions: Bausa
j3bu5
I've been working on a concept build for an ITX solution with external rad's. Up until now I've been looking at console cases to show off as much of the hardline tubing as possible. Up until now, I've had difficulty finding this style of case with an area I can mount some decent passthroughs for the external bits... however I noticed your case in a recent review actually has pass troughs built into it, which makes this MUCH easier. I've still got to read through the rest of the 100 pages or so of this thread, but i may well throw my name in the hat for this. Thanks!
