Can you share what/where you got these terminals for double crimping? I'm interested in daisy-chaining the PCI-E cables. Are those PCI-E cables 16 AWG?
Additionally, I believe I found the picture where you installed a Quadro; is that a Quadro between the mobo and psu? Can you please verify this? I also noticed another photo where you have a device that looks like an aquacomputer for measuring flow and temp. Can you please let us know what that is?
I'm also trying to figure out how to get a flow/temp sensor and have that control the 3-pin pump. Is this not possible with the Quadro? I would have peace of mind if I could find a way to do this. I might need to just buy a PWM pump that is not discontinued.
Thanks!
Here we are!!
So, the AWG cable are 17AWG, and the "longer terminal" that allows to have an easier double crimp are these:
50x ATX crimp terminals FEMALE Minifit-Jr for ATX, PCI-E and EPS, made for 16 AWG and 15 AWG (1.50mm²).
www.cable-sleeving.com
Yes, the QUADRO is installed using just one screw on the PSU bracket, near to the MB. Actually, you can mount it also in other spots like near the front NVME, ecc.
You can even have it not fixed if you have trouble to fix it, or use some velcro strap.
For your temp/flow, well, the one I am using is an AquaComputer MPS200 that has an integrated temp sensor header, and one internal.
The problem with the 3-Pin pump is that you can't control it with the QUADRO.
BUT there is a solution, and is called PowerAdjust 3:
https://shop.aquacomputer.de/product_info.php?products_id=3196
It control the DC pump based on a temp sensor header if you want (BE careful, you can do this ONLY if you use the integrated thermal header, and not some on other devices). It has also a flow port to connect to a bulky but really good (mechanical, so precise reading) flow sensor:
Durchflusssensor high flow G1/4 für aquaero, aquastream XT ultra und poweradjust: Durchflusssensoren von Aqua Computer können leicht in den Kühlkreislauf integriert werden und ermöglichen eine kontinuierliche Durchflussmessung. Dieser Durchflusssensor wird mit einem sehr niedrigen...
But you need a separate cable for this.
For the pump, IMO the best for availability etc is the DDC 1T Plus PMW!
Laing DDC-pump 12V DDC-1T Plus 4.2 PWM kopen bij HighFlow.nl. Voor iedere gamer een gewenst model. HighFlow levert alles voor waterkoeling. ✅ Gratis verzending va €150 ✅ Altijd Euroknallers
www.highflow.nl
