Prototype efficiency laboratories pcc-02.x-series test bench
el01
770
588
pcc-02.x
This is a test bench designed for the efficiency laboratories pcc (project communal cases) lineup of open-source chassis designs.
stock specifications:
physical:
lxwxh (mm): 192x176x211
size (liters): 7.130112
weight (grams): 220
hardware:
max cpu cooler height: <120 mm*
max gpu length: 185 mm*
drive support (3.5"/2.5"): 0/6**
power supply support: SFX, SFX-L
motherboard support: DTX, mini-ITX, STX
*hypothetically infinite. 120mm/185mm values used for measurements and volume
**7 or 5mm drives supported
add-ons
  • 3.5" drive mount: adds support for 1 drive to the system
  • modular fan mount: adds support for up to 2 120mm fan mounts and support for push-pull configurations on all-in-one liquid coolers
  • coming soon: adjustable cable management "ties"
more pictures available at:
https://www.flickr.com/photos/165204374@N04/albums/72157693510700830/with/41748796490/
do you like this new format? Tell me below! :D
