Prototype DAN HSLP-48: A powerful sub 50mm heatsink
paulesko
415
322
Also my black ridge arrives on monday, I can put here my temps cooling a 3700x and compare it to a big shuriken 2 (old one) and also a scythe mugen (old one also) which are not compatible with am4, but I can manage to adapt them...
Hellow
160
27
I'll monitor a stress test later this week-end. But y, even more far. I'm already around 80°C while gaming so...
paulesko
415
322
theres a video on youtube where they test it (optimumtech) and it doesn´t seem better than the copper one.
I´m also having difficulties controlling temperatures on my 3700x it just has too much voltage ... so it´s hot.
Instran0
526
107
i'm aware, but a sample size of just 1 reviewer isn't scientifically sound.
if that 1 reviewer installed it incorrectly, then the whole sample is corrupted.
we need a bigger sample size to adjust for that.
Instran0
526
107
i think i installed my BlackRidge in push, instead of pull, & its throttling under load.
which is a fail.
i didn't think anyone wanted fail results.
rapidshrub
42
48
which is a fail.
So blowing upwards, away from the motherboard?
Asking because mine came installed on the heatsink that way and temps aren't great but I've never used such a low profile cooler so I can't compare to anything. I've been too lazy to flip it but plan to.
Instran0
526
107
honestly i can't remember.
but i failed.
which is why i'm asking for other's temps.
not because i didn't purchase a BlackRidge; because due to my lack of skill, the installation was a fail.
Poblopuablo
816
465
are you located in the USA ??
if so, i would be willing to assist you in getting items, for comparing both coolers.
as you can see from above, i'm highly interested in getting a comparison between coolers, however very few people have used a 120mm fan with their BlackRidge V2, and then written down temps.
many people keep saying they've used a 120mm fan, but forgot to write their temps, which is not helpful.
@GucksTV also seems to not write temps in English, or has them so they're unreadable, within his videos.
not helpful at all.
Yes I am. If you're on discord or Reddit unusually am on there more if you want to
dm. /u/poblopuablo
Or poblopuablo#2344
Poblopuablo
816
465
Yes, I have VLP Ram that is Samsung B-die. I'll be using the recently released tool to OC it this weekend but it should have good performance compared to the Adata sticks. I got them off of an eBay seller in the UK. They're still for sale, though a bit cheaper than I paid at £79 for 16GB sticks at the moment. The description is "innodisk (Samsung) 16GB DDR4 2400 PC4-19200 VLP UDIMM RAM M4C0-AGS1TCSJ". Currently I'm at 3200MHz CL17 but we'll see how I go over the weekend.
I don't see the one you are talking about, but I see this one:
According to manufacturer these are ECC( for server/HEDT) sticks, do you think they would work with a b350 system?
Edit: source: https://www.innodisk.com/en/products/dram-module/server/Unbuffered_w_ECC_DDR4_LONG_DIMM_VLP
Instran0
526
107
someone else can correct me if i'm wrong, but believe you don't want " ECC server " RAM, because its not compatible.
Poblopuablo
816
465
That was my understanding, but according to @Van0 he was able to get it to work, albeit idk what his system is, so it might be natively compatible.
Hellow
160
27
ECC ram run on a non-ECC mode on some motherboards. At least it's the case with Gigabyte.
Read the spec of the motherboard to see if it supports ECC Ram.
Poblopuablo
816
465
I have an asrock fatal1ty b350i, according to their page it will accept ECC ram for some cpu's. But it doesn't say if it will for Pinnacle Ridge (2700x). But I think it will. This is good news. :)
Thanks!!
PantherB
31
28
Thanks!!
I have the same mobo and bought the ram from the UK eBay reseller, works perfect.
PantherB
31
28
Can all 3700x users with a black ridge+120mm fan share which mobo they are using?
I have a ASRock b350 gaming itx and I don't have to mod the vrm heatsinks. Is there a compatibility list for this thing with a 120mm fan?
