Due to the CPU itself not being centered on the motherboard, i don't think it will work (unless I don't understand what you are saying)Is there actually a mounting-kit to mount the Black Ridge in a 90° position?
These could maybe solve the compatibility issue for 570x boards (together with vlp-ram)…
I imagined something like Noctua's NM-AM4 kit which allow 90* rotation.Due to the CPU itself not being centered on the motherboard, i don't think it will work (unless I don't understand what you are saying)
I would say yes...Hello guys !
I'm actually looking for my future motherboard. For this Black Ridge, the only B550 motherboard that doesn't seems to need any modding is the Asrock B550M-ITXac, right ?
Thank you :-)
Do be aware; the ASrock socket location is a bit lower on the board. The Blackridge is only good for sandwich cases with this board; the MSI and Gigabyte PCBs have the socket slightly higher and would be good for console layouts paired with the Blackridge. You would need to remove the top cover of the NVME drive, but I don't consider that "modding."Hello guys !
Thank you :-)
Whichever you choose, good luck on your build!
How is it for temps? Is there much difference between that fan and an NF-A9x14?I did a small experiment with a 100m fan that has 92mm mounting holes, the thermalright TY-100BP. It fits in the Blackridge with the Asus b450i Strix motherboard and does not conflict with the IO nor ram.
thermal paste should do its job to seal any blemishes or fine depressions/air gaps between the cold plate and the CPU IHS.. I dont see a need to worry.I ordered a black ridge recently and it appears like the cold plate has some severe blemishes. Is it worth getting some sandpaper and trying to sand it smooth or will the thermal paste do the job?
I already mounted it so I can’t easily show pictures but figured maybe others had run into it as well
Black ridge main flaw is assembly on motherboard. Nowadays there are more incompatibilities than the contrary.My black ridge, using the k39 case, gets the fan clips hitting the riser pcb even after I removed the b450i m.2 heatsink. Not managing to seat the cooler decently. Waited 20 days por my Vlp and now the cooler won't fit with the 120mm slim underneath.
