Hm, my brain must have shut off for a moment, I was sure those were 1200rpm max. Something obviously short-circuited there.800? P12 goes up to 1800, A12 up to 2000 rpm.
Probably that 800 part in 1800 hahaHm, my brain must have shut off for a moment, I was sure those were 1200rpm max. Something obviously short-circuited there.
What's the max radiator + fan thickness in the same configuration? i.e. the distance from the bottom to the motherboard edge.With 143mm in width it will be a very close fit but it should work.
Wasserkühlung Radiatoren mit Lüfteranzahl 140mm einseitig: 2x 140mm, Breite bis 143mm, Länge bis 320mm, Höhe bis 30mm Preisvergleich Geizhals EU
Preisvergleich und Bewertungen für Wasserkühlung Radiatoren mit Lüfteranzahl 140mm einseitig: 2x 140mm, Breite bis 143mm, Länge bis 320mm, Höhe bis 30mmgeizhals.eu
If you cut the corner of the 140mm fan it will fit.
Yes, but on sandwich layout.You mean fans on both sides of the rad?
Can you make sure Linus actually spreads good information about the case and the compatibility? I get that they are an entertainment channel more so these days, and that having your case featured on there is great for exposure. They just gloss over a lot of things and don’t properly plan out builds in SFF cases they review so it leads to people thinking that SFF is extremely hard or not doable to beginners.Samples are now rdy to ship. I will start with Optimum and Linus.
On the A4-SFX he did a great job. Like the last cooperation i will send him all important information and example configurations. I hope he will do two video:
Crazy Build: Epyc 64c, 280 AIO, deep itx and RTX A6000.
Review: Ryzen 16c, 280AIO, RTX 3080 (classic & sandwich)
They did an impressive job on the Loque Raw S1 recently, so they might have started to understand basics like "check if your GPU and CPU cooler are compatible".Can you make sure Linus actually spreads good information about the case and the compatibility? I get that they are an entertainment channel more so these days, and that having your case featured on there is great for exposure. They just gloss over a lot of things and don’t properly plan out builds in SFF cases they review so it leads to people thinking that SFF is extremely hard or not doable to beginners.
i could be off base on my criticism of LTT and how they review SFF cases, but I feel with better planning on their end they can be better.
