DAN A4-SFX v4.1
Admiral
Very excited. Will the 120mm fan mount above the motherboard accommodate a 25mm thickness or just 15mm?
That's what we're discussing with the talk about "A4 XL". The difference between 25mm and 15mm is a full centimeter (duh), and that's kind of a significant delta. For my money, we'll already be adding quite a bit of thickness if the case accommodates a Noctua NH-L12S.
DarkCanuck
58
28
@dondan I should put this in context: a 120mm x 25 mm fan over the motherboard with an AIO, and the radiator positioned in another location.
fabio
1,885
4,325
Hey @dondan , could you say to us if the Dynamo 360 is supported by the V3? Has it the same mounting point than the HDplex 400?
Woxys
Would be someone interested in a A4-XL that has an increased width from 114 to 130 so you can install air coolers up to 66mm like the Noctua L12? I am also interested in using uni body desgin (no inner frame) for this version to bring the costs down. This design has also the future potential to use die stamping to reduce the costs a lot. I don't know if a case like this could co exists with the current A4.
The size would be 130x312x200 (WxLxH) = 8.1L
Yes.
Aux
179
156
Are you sure? You can easily buy it from Noctua directly on Amazon.
Noctua website says discontinued and points at the L12s, so there may still be L12 parts out there for a while .
L12s is 70mm
ooops, didnt see Fabios post saying the same
Reactions: fabio
PantherB
31
28
@dondan in a hypothetical dan-a4 XL, do you think a Noctua L12 with a slim 120mm fan mounted below or a blackridge with 92mm below+120mm slim fan upon the heatsink (total height 47+15=62mm) would be superior?
DarkCanuck
58
28
@dondan where do you anticipate mounting of the HDPLEX 400W.AC-DC brick in the A4 v4? Do you anticipate that it will be compatible with also having 2x 92mm fans on the bottom of the case and (obviously) having the HDPLEX 400W Hi-Fi DC-ATX mounted?
AseDen
Asetek
Dec 7, 2018
194
295
www.asetek.com
Assuming that A4 XL can take what looks like 240mm worth of rad, YES! :D
I'm currently running an i9-9900k with an Asetek 545LC. Suffice to say that its struggling to keep that monster cool. My #1 option was a Dan C4-SFX, the A4-XL would be my second. Assuming they take too long to get to market I may have to look at an NCase/Ghost but I'd much rather stick to one of your products. The build quality of my A4 is amazing! It simply cannot handle the heat that the 9900k produces. :(
Hopefully our new solution will help with this. Still waiting for sample, but I do have a 9900K and blowstyle 2080 next to the A4 on my desk, at the moment ;) #BringTheHeat, right? ;)
fabio
1,885
4,325
Fingers crossed that the improvements can handle the 9900K. Eventhough it is difficult to cram that much cooling into a 92mm radiator and slimfan ;)
Let’s hope!
My 120mm rad with a Noctua A12x25 at 1100rpm cool it around 85 degrees under Prime with AVX offset of 4, so all core at 4.6ghz. MCE enabled, no power limit, it is in idle at 30 degrees. In the DAN case of course!
Reactions: jrkd
AseDen
Asetek
Dec 7, 2018
194
295
www.asetek.com
Let’s hope!
Oh wow... Didn't realize the 9900K got THAT hot. We're thinking most people will be using the Noctua NF-A9x14 with our product, which only provides half the airflow at full speed.
Now I am not an expert in airflow and aerodynamics. But assuming that airflow is linear with speed (which it is probably not), the NF-A9x14 would have roughly the same airflow at full speed, as the NF-A12x25 at 50% speed.
Taking the smaller radiator into account, that would mean higher temps. But should stay below thermalthrottle. This all depends on radiator thickness, material, pumpspeeds etc. of course.
fabio
1,885
4,325
Indeed! I am using the Eisbaer LT Pump, that is a 2800RPM pump and a normal 16 Fin 25mm Rad from Alphacool. I've shortened the tubes to have a better fit.
Let's see! Maybe limiting the CPU at 160/180W will work with no problem!
fabio
1,885
4,325
I hope to receive soon my HDplex!!
@dondan one small question: the plastic division is supposed to be removed with the 120mm AIO setup?
