Oof that sucks. I doubt it.Is it possible to remove scratches from the exterior side panel?
Hoping mine will ship on the 24 may from sfflab ?Just for everybody from Germany...Caseking listed the Dan A4 V4 since yesterday and it should be available around the 12.06.2019 which is a bit later then I wished it to be, but should be a nice timeframe for the new RYZEN 3000 series to be launched aswell!Great timing! <3
Oh nice one! Can't wait.It should ship relatively soonish as I got mine a couple weeks ago.
True. I won't be building for at least 2 months. I should probably wait and seeDunno as I'm waiting for the x570's to launch at computex to see how I'll lean.
Based on some quick googling, that cooler should fit as the dimensions are from the 4 holes for the mount and the heatpipes dont exceed that distance.Does anyone know if it's possible to put a Cooltek LP53 on a z270i Pro Gaming Carbon AC ?
As we can see here there are two big heatsinks at the top and bottom of the socket, and I'm not sure if the heatpipe will touch or go above them..
It will be close but neither should have much radiative heat transfer between them.
im not the first to do this. its simply a 10mm fan up top and and 3d printed bracket.
im most likely gonna try fit a noctua 14mm fan up top by maybe, juts maybe vandalizing my case. but well will see when i get all the parts![]()
Dan Case A4 v3 - 80mm x 10mm - Top fan bracket by bungwu
Top mount bracket for an 80x10mm fan to go into a Dan Case A4 v3. Friction mounts to the case frame.I am using an Akasa Slimfan 80mm x 10mm PWM Fan (AK-FN076).I had lots of issues with the fan rubbing the riser cable when using the fan as an exhaust. I am using a LINKUP riser instead of stock.I...www.thingiverse.com
I'm about to build in the A4 v4 I just received this week, still waiting on a NF-A9x14 to go under the motherboard (and some pslatecustoms cables but it shouldn't arrive anytime soon).
Anyway I was wondering if the 645LT should suck in fresh air from the outside of the case or use hot air from the inside of the case?
I'll have 3 90ish mm fans pulling air into the case with the RTX 2070, and probably the fan under the motherboard pushing air out of the case.
Ideally I'd like to create negative pressure to get more fresh air into the case through the vents.
Drawback is that I'll probably get more dust into the case, I might buy some dust filter to counter that.
