- added thread for easy installation of custom window kits
That’s super interesting! Thanks man!Maybe with this you can mount the pump on the hd plex location:
https://www.alphacool.com/shop/pumpen/pumpenaufsaetze/13013/alphacool-dc-lt-plexi-aufsatz?c=20556
https://www.alphacool.com/shop/pump...-dc-lt-3600-12v-dc-pump-industry-bulk?c=20556
Or double pump. Maybe this will also work with RTX 2080 (270mm long card):
https://www.alphacool.com/shop/ausg...dual-dc-lt-5-25-single-bay-station-rueckseite
Today I got the A4-SFXv4 samples. I will show some pictures tomorrow on day light. I love USB Type-C![]()
Is the Nvidia 2070 FE, bought on the Nvidia website!Fabio, what 2070 is that? The cooler looks nice
Anyway, just ordered! Let's see!!! It will be great to keep the possibility to use the Titan RTX and a proper custom loop!Maybe with this you can mount the pump on the hd plex location and it could work with full length RTX FE (270mm):
Or double pump.
cannot wait!Today I got the A4-SFXv4 samples. I will show some pictures tomorrow on day light. I love USB Type-C![]()
CPU: Intel 7980xe delidded, with liquid metal + copper plate + kryonaut paste
CPU cooler: Asetek 545LC + Noctua NF-A9x14 in pull config
Motherboard: Asrock X299E-ITX/ac
I can run a couple of threads at 4.7GHz, or 36 threads at 3.9. On a bigger mobo this CPU goes around 4.4G Hz on air, 4.6 on AIO with 36 threads. But the problem is, with all cores in use this case starts to accumulate heat and it doesn't get out fast enough. Doesn't matter if I clock them down to 3.2GHz, the heat just starts building up slower, but eventually hits unsafe temps.
That stock Intel cooler makes feel nostalgic. Great job!hi everyone,
my 1st dan a4 sfx v3
Yep, is that. Is easy to remove also without heatgun!Is that perhaps the ASUS ROG STRIX Z390-I GAMING motherboard by any chance? Only that you've removed the "font stIcker" on the lower part (upper side on your image) of the I/O cover?...
Looks to be a G-uniq kit.Fabio, what are you running as a psu? I skimmed back a few pages and couldn't find the the answer... I can't tell it it's G-unique or HDPlex. Using your above-pictured build as a reference, do you know if the HDPlex AC-DC adapter would fit anywhere in your case? Either above or below the gpu, or, somehow heinously mounted in front of the mobo?
Specs are listed here https://www.hdplex.com/hdplex-internal-400w-ac-dc-adapter-with-active-pfc-and-19vdc-output.html
