I'm building my machine now. I just want to say, whoever said the ASETEK 645LT was designed for this case was full of shit. Believe me when I say I'm trying to stay positive.. but..
One of the circulation hose fixtures binds at the graphics card, deflecting it towards the case side panel -- the center (spinning) hub of one of the card's fans is definitely going to be rubbing the panel while it's spinning! I can make it work by removing one of the two snap-in female receptacles that helps to keep the case's side panel in place, the one from the power supply side (leaving one plus the two screws on each side... which should be OK, but kludgey). Guess I'll find somewhere else to drill a hole for a new screw to make up for it (countersunk, even.. this will be fun :/ ) . The cooler still touches, but not so bad. Why couldn't they have just moved it over? I guess that would be a full redesign of the radiator, and who knows what else.
Without doing the above, the cooler also binds at the power button, and I'm pretty sure the screws of the "recommended" Noctua A9-14 slim (installed on the cooler) intrude into the pcie 2-width form factor (lucky the heatsink cowling for the card tapers in as it comes off the card!). Forget about using the stock PSU cables (Corsair SF600), and I'm doubtful that there is more than a millimeter between the Molex connectors and the cooler's fan, so even that seems unlikely. I know you guys with custom cables have done this, but wow. Unless I've missed something, it seems like removing that snap connector is the only way to do this right.
So three hours in, going to try again tomorrow. I just love how the box came with an ad for this cooler too.. No instructions to support it though, from either company, haha! I wills say however that I am impressed by the quality of the case build and the production value of the case instructions.. fwiw
