Stalled Custom_MOD MINI
bakakiba
Im using a pretty old setup and dont wanna change when there is barely any noticeable performance increase for my needs and this is what i use today:
2500k
asus p8z77-i deluxe
16gb ram
750ti with accelero
Plan is to invest in the case, N9i, new 1050ti with silent fan which fits the case. And the goal is has the system as quiet as possible.
n3lonen
I notice that gigabyte made gtx 1080 mini itx gpu. So maybe I have to order 3.5 litre version some day. Beautiful case.
Ketchup
49
28
@bakakiba, fair enough. If your system meets your needs, why spend money. And the 2500 is a good processor. I don't think you'll have to much trouble with heat and noise. I myself am waiting for batch 7 to arrive. I'll post some details once I get it. I have a i5-6500 with a GTX 1060. Not the same as you, but it will give you some idea.
Xydal
Would like to know if anyone ever tried to use the 4l with a 1080Ti mini, if so, how was the heat?
Also is the dell power adapter included when ordering with g-unique PSU or it must be purchased separately?
Revenant
Revenant Tech
1,741
2,858
Seems that way. I'm hoping to see the #8 blanks come back soon. I have a bunch of parts just waiting for this case.
Ketchup
49
28
I've been using a clipboard with the motherboard screws under it since January until I get my case. It surprisingly does a good job. I use the paper holder to hold my hdd. If I had the G-Unique PSU with that, It would almost be an interesting open air setup. I could just hang in on the wall. lol!
Reactions: InfernoZeus
paullusty
51
https://www.google.co.jp/url?sa=i&r...aw061sSBIeUWNszytNT1D3-N&ust=1508610205570193
i was useing these taped together with some vent holes till mine came lol
QuantumBraced
507
358
I'm looking at the specs of the 3.5L case. Question -- if the case is 190mm long and supports a 7mm drive mounted at the front, how can GPU clearance be 185mm?
QuantumBraced
507
358
The clearance for the video card is without the hard drive. If you want to add a hard drive, i suggest the 4.0L version.
The 3.5L should still fit a 1080 Mini plus a 7mm drive though, right? I'm thinking it may even be possible to fit 2 SSDs taped together with very low-profile double sided tape. Because the 1080 Mini is 169mm + 14mm for SSDs = 183mm, which still leaves 2mm? I have 2 SSDs and I'm wondering if I can use this case...
ryandvd
25
48
I also ordered 3.5 from batch 8..Sergiiua told me that i can also used my existing one 2.5 ssd in this case..
Flybird
@dananglabs, did you order your G-Unique by yourself or did you go through @sergiiua? I'm asking because I ordered the full kit from Sergiiua and I don't want to have the same problem as you considering that my pin layout is positioned at the same spot as you.
g-ubique is my friend,if you want order something,i can help you.
sergiiua
CustomMOD
Jan 11, 2017
1,154
2,053
www.custom-mod.com
now we will make version 4.8L instead of 4.0L. You can install a large CPU cooling cooler. Also a large video card and several 2.5 "
CASE
MINI itx 4.8L rev.4
Specs:
- Volume: 4.8L (115mm x 185mm x 225mm)
- Weight 1kg
- GPU: length <215mm, height <132mm (ZOTAC GTX 1080ti mini compatible)
- CPU Cooler: up to 50mm (CRYORIG C7 compatible)
- RAM: up to 50 mm
- Storage: M.2 /2xSSD 2.5"
- PSU: DC-ATX G-Unique 400W
- PCIe riser: LiHeat 300mm D.type
Reactions: Acalanata
sergiiua
CustomMOD
Jan 11, 2017
1,154
2,053
www.custom-mod.com
Attention, open Batch # 10 (5 cases limit)
1. Now we will accept orders with individual size separately from the base cases. To order non-standard cases, we prepare a separate order form. This will help not to waste time and do ordinary orders on time.
2. The first two customers will receive a 20% discount on the case (applies to standard cases)
3. For those who have already received our case of past audits, there is a 50% discount (Batch # 10 2 cases limit)
TheHig
951
1,171
So I can get 50% off of this case since I already purchased a Custom Mod Mini?!
So tempting..
And pics of the 4.8L version?
