Production cases FX 4.2L / FX 4.9L by Custom_MOD
Frazhna
29
Where did you get that black seasonic flex atx power supply? It looks fantastic! Did it come with sleeved power cables? (I'm very excited for this case)
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Made mod. I'm a modder for me that's not a problem. https://smallformfactor.net/forum/threads/mod-psu-flex-seasonic-ss-250su.2404/
Seasonic SS-300M1U - 75$
Noctua NF-A4x10 FLX - 15$
Modular wires of special length (without braid) - 30$
1x24pin ATX - 13cm
1x8pin EPS - 16cm
1x8pin PCI-e - 20cm
1x5pin SATA - 15cm
Wires black, connectors black.
Painting the power supply enclosure - 10$
Worldwide Shipping - $25
Total $155
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
- Tomorrow is the last day of the order of the current batch.
- The plant today reported a breakdown of one of the bending machines. They work around the clock to make it. Promised to do everything tomorrow and send it to me. I apologize for waiting.
Jonny727272
275
218
That is flipping beautiful!!! Have you considered partnering with a bigger company to help spread your case, kind of like what is happening with the LZ7 and OverclockersUK?
Reactions: AleksandarK
Johnboy
Gents. I know this question was made more than one time but I didn't see a direct answer 'till now:
Does a HDPlex 400w will fit?
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Party 2 will receive revision 2. The main change is an increase in the width of the case by 3mm. Thanks to this we were able to strengthen the design of the case.
CASE FLEX mini 4.1L rev.2
Specs:
- Volume: 3.99L (220mm x 181.5mm x 103mm)
- GPU: length <175mm, height <132mm (Giga 1070 Mini and MSI 1070 Aero ITX compatible)
- CPU Cooler: up to 39mm (Noctua L9i recommended)
- RAM: up to 42 mm
Reactions: Acalanata
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Guys we ordered new buttons with LED backlighting. If you want to change the button for your order, write to me.
12mm black (backlight White)
12mm black (backlight Red)
12mm black (backlight Blue)
12mm black (backlight Green)
16mm black (backlight White)
16mm black (backlight Red)
tecent
Hi, Zotac is currently releasing a lineup of mini cards up to 1080ti with size of 211mm x 125mm x 41mm (8.31in x 4.92in x 1.61in).
It seems like they are pretty committed on releasing mini cards in this size.
Just curious if you might be interested in revising your design to fit such sizes?
Thanks!
sergiiua
CustomMOD
Jan 11, 2017
1,143
2,042
www.custom-mod.com
Thanks!
So soon there will be such a corps. Already ordered blanks. Soon announcement.
Reactions: tecent
Maestria
64
99
Is this my case in the pictures ? :cool:
If you can do this mod for the incoming 450W platinum seasonic psu, i would definitely buy one ;)
Maestria
64
99
300W is sufficient for maximum configuration. (i7 7700k 91W / gtx 1070 mini 150W)
It's true but i m looking for platinum to minimize noise.
On typical load like gaming it will draw around 220-250W.
On 230V with 300W Gold it will be 90% efficient so 24-27W heat to dissipate.
With 450W Platinum it will be 94% efficient so 14-16W heat to dissipate.
