Production Custom_MOD case SX & SXM
Flexon
Images working now!
"- Storage: 2 x SSD 2.5"..."
Does it have to be SSDs or can I use a 2.5" mechanical HDD?
hardcore_gamer
electronbender
Aug 10, 2016
149
123
Is there a way to use a slim AIO for CPU cooling ? If no SSDs are used, can a slim 120mm radiator fit in that space ?
cd109876
Apr 1, 2017
Hi,
Would the normal Intel stock/boxed cooler fit in this case, or would there be problems?
I'm fine with it touching the side panel as there's a peice of plastic that would prevent the fan from hitting the side panel, but I don't want it to bulge the panel (much).
Thanks!
sergiiua
CustomMOD
Jan 11, 2017
1,033
1,853
www.facebook.com
Hi,
Thanks!
Max height of CPU Cooler is 45mm.
Just search the height of your boxed cooler in the web. Because there are many different cooles for different cpu.
multi
Need connectors for headphones and a microphone. With my power supply SX700-LPT on the left side of the body will fit 3.5 * hdd, you need a fastener for it. Can I make it all an option? And very cool if there were regular places on the side panels for dust filters.
stevey500
46
37
I agree with this too, but on the inside of the case rather than the outside. While external (especially magnetic) filters are convenient, they don't look great, they just cover up the beauty of the case. On top of that, they're just restrictive which is the opposite of what we want in a small form factor build; the smaller the case, the quicker it is to just take a can-air to the whole build and be clean within seconds.
cadiguno
128
116
I hope it's just Easter holding up the prototype and not some serious problem...
stevey500
46
37
Looking awesome! I really like that all of the panels are removable separately. This makes for far quicker system hardware changes and potential DIY user color modifications. ;)
