Stalled Compact 24L water cooling oriented ATX case
3lfk1ng
919
1,718
Santa Barbara
www.reihengaming.com
Or unless I am misunderstanding... (missing from illustration: PSU mounting bracket)
Boil
1,263
1,100
Grand Junction, CO, USA
I believe it is stated in the thread that if one uses a top or front mounted PSU (no matter the size; SFX, SFX-L, or the non-supported ATX), there are compromises in radiator size...
That is why there is the option for a SFX or SFX-L PSU to be mounted over the MB, freeing up all front & top space for full-length radiators...
And realistically, who is going to feed hot air from the radiator thru the PSU..?
4,796
Ah, I forgot the case was inverted and said bottom 240mm. What I was talking about was switching just the positions of the ATX PSU and 120mm rad here:
Though now that I look, even with the rad pushed as far back as the frame allows an ATX PSU wouldn't clear the 240mm without increasing the depth of the case.
4,796
If the front IO design didn't change, the depth would have to increase about 60-70mm to fit a 360mm rad.
Wahaha360
a.k.a W360
2,131
10,697
USA
Style #2 is a design / brand pigeonhole. I don't think it makes sense for this new layout to be similar to the M1 unless function demands it .
To keep the series separate, I think style #1 is the better choice.
Disclaimer: I prefer and therefore partial to the rounded corners on style #1, and I don't want to make same looking case, it feel like we are not moving forward.
grumpyrobin
260
190
Well I like the trapezoid edge front panel on style two and rev3 steambox.
Something round like style one can definitely work but it is missing that I-dunno-what that the trapezoid edges have that put them far far ahead in my book
Reactions: darksidecookie
6,125
5,032
Belgium
Purposefully designing something completely different from your first product also seems like not moving forward. You'd only want a different design if the different design is better, not just because it's different.
I personally dislike the rounded corner model. Project Sidearm and the 7L concept are amazing though in my opinion.
QuantumBraced
507
358
I love this concept, already given it a lot of praise and thoughts/questions on [H] :) But I had one question related to a comment Necere made here:
We're going to try to do steel for the chassis, actually. But this is far from final, and will probably see several revisions. You should have seen how many revisions the bottom vent pattern on the M1 went through...
Steel? Why? To keep costs down? It will be much heavier and brushed aluminum is hard to beat looks-wise.
6,125
5,032
Belgium
Marketing Guy: also because of the use of thinner gauge steel, it can truely capture the SFF spirit with increased efficiency !
Probably also general strength I'd think and it's also easier/cheaper to laser, so a strong and flexible (buildwise) case with a reasonable price.
Necere
3,300
I believe Necere is referring to the inner chassis, the exterior panels (excepting the back, which is part of the inner chassis) should be aluminium...?
Steel is stronger, so you can use thinner gauges. It's cheaper. But knowing the NCASE crew, the main reason is probably for compatibility with magnetic dust filters.
Magnetic filters is one reason, but also a lower likelihood of stripped threads. And yeah, chassis only. Outer panels would still be aluminum.
Necere
3,300
Here are a couple alternative configurations for people who want to water cool but don't want the PSU blocking the motherboard.
Both would replace one of the 120mm rad sections with a 92mm rad at the rear. The first one is limited to regular SFX only, while the second allows for SFX-L, at the cost of only being able to use a microATX motherboard.
darksidecookie
115
141
Belgium
would it be possible to keep the atx form factor and sfx-l if you where to flip the front rad so the ports are on top, and chose the top rad with ports like below so you could put them both in parallel?
just an idea, might not be possible tho
