UPDATE December 2017: this project is on hold for the time being.
Original post follows below:
This concept is a compact, water cooling-oriented inverted ATX case, with flexible mounting for fans/rads, PSU, and drives on the top and front. The flexible mounting allows you to make different trade offs based on your needs. For example, mounting a radiator or PSU at the top will block off some of the expansion slots.
Preliminary specs:
Dimensions (H x W x D): 350 x 180 x 380mm, 24L
CPU cooler: ~145mm
Motherboard: inverted ATX, 8 slots
Front fan mounts: 2x flexible 140/120mm
Top fan mounts: 2x flexible 140/120mm
Rear fan mount: 1x 92mm
PSU: SFX/SFX-L, flexible mounting
Radiator support: Up to 1x280 in front + 1x240 on top
Drives: TBD
Window: optional
WIP interior pic:
I'm also playing with a couple different directions for exterior styling:
#1, rounded style
#2, M-style
I'd like to hear which design direction people prefer, as well as any other feedback or thoughts people might have.
Preliminary specs:
CPU cooler: ~145mm
Drives: TBD
Window: optional
WIP interior pic:
#1, rounded style
#2, M-style
