Prototype cirrus7 incus - fanless case for ASRock DeskMini A300 and other popular STX sized boards.
cirrus7
Cirrus7
Mar 13, 2019
25
www.cirrus7.com
Introduction:
We have been working on a passivly cooled STX design lately. This form factor has gained quite some interest since ASRock has launched its DeskMini A300. The DeskMini A300 is a nice SFF Barebone system based on the AMD Ryzen CPUs with a powerful Vega 11 GPU integrated. The idea behind the cirrus7 incus is to provide a fanless, passively cooled option for that platform and also for other popular STX mainboards (Intel Gemini-Lake / Intel Coffee Lake). There will be case only options as well as fully-equipped and preinstalled PCs to order.
Principal of the design:
Like our other fanless models the whole case is built out of individual CNC cut aluminium plates which are connected by common copper cores to distribute heat evenly. The main cooling plates are perforated which increases natural convection by approx. 40%. Due to the modular design it is possible to adjust cooling performance by simply adding more plates. Therefore there will be different case options for 10W / 35W / 65W CPUs. We do mill our cases on our own CNC machines inhouse. This way we are able to do fast prototyping and fast design-to-market times.
Case Details - Different Options:
Incus-ASRock-A300-35W - For ASRock DeskMini A300 with 35W TDP Ryzen CPU
Dimensions: 195mm x 169mm x 92mm
Material: Aluminum, Copper
via Sketchfab
Incus-ASRock-A300-65W - for ASRock DeskMini A300 with 65W TDP RyzenCPU
Dimensions: 195mm x 169mm x 124mm
via Sketchfab
To Be updated soon:
Incus-Fujitsu-Gemini - For Fujitsu D3544-S industrial mainboard
Dimensions: 195mm x 169mm x 52
Incus-Fujistu-CL-35W - For Fujitsu D3654-B mainboard 35W
Incus-Fujistu-CL-65W For Fujitsu D3654-B mainboard 65W
Let me know what you think. Feedback is highly appreciated.
Donut
54
35
That's a very elegant design! Do you have a prototype that you've used for temperature testing? If so, and if you don't mind, I have some questions:
  • It appears that the primary design difference between 35W and 65W is the number of aluminum fins. On the consumer end of things, would we have the option to have more fins than what you show here (if we want to over-do it on the cooling)?
  • On a related note, what's the maximum reasonable number of fins that could be used? I'd imagine that at some point, more fins doesn't do much because the heat can't travel to them through the copper cores quickly enough.
  • How well can the 65W case handle a combined CPU and GPU load with the 2200G or 2400G? My 2400G draws a lot of power and produces quite a bit of heat in some scenarios.
  • I dug around in your site a bit after reading this and noticed that you also have a case for coffee lake/thin min-itx. Have you compared the cooling of that case with this new case, using the same processor (e.g., an I5 8400)? I'm wondering how much thermal performance we'd have to give up by moving to the smaller case.
  • Because these seem to be tailor-made to specific motherboards, is it possible to have the case act as a heatsink for mainboard components (like the VRM) as well? This may be useful for the 65W processors.
cirrus7
Cirrus7
Mar 13, 2019
25
www.cirrus7.com
Thanks for your questions Donut. Excellent points. Yes we are entering the prototype status at the moment and doing the actual CNC programming and milling during the next two weeks. So of course we will do temperature testing and provide numbers here. The number of fins are based on calculations and on our current experience with Thin-ITX (Coffee Lake) and NUC based models. Also we did some testing with the fan-equipped DeskMini A300 with a 2400G to see how package power behaves under certain loads. That being said. It is quite possible that there will be more fins on the final product for the 65W version if the current planned number of fins is not sufficient.
  1. That would be possible if requested. We have a similar approach with the cirrus7 nimbus. Here we have three different types of "cooling editions"
  2. The reasonable limit is likely more limited to costs and manufacturing limitations. Of course the heat transfer is limited on the copper cores. But one could easily increase the number and diameter of the cores to increase heat transfer. This is what we have already done with our models now. The Gemini Lake model will need only one copper core. With the 65W model we will go with 5 or maybe even 8 cores.
  3. Goal is to do it without throttling and reasonable temperatures under full load. Same as we did with the cirrus7 nimbini : https://www.cirrus7.com/blog/cirrus7-nimbini-v2.5/ I'm pretty curious to see how the 2400G behaves under combined CPU / GPU load vs. prime95 only load.
  4. The goal is not to sacrifice any thermal performance compared to our Thin-ITX platform (cirrus7 nimbus). First of all will get an update as well. It does not have the perforated fins yet. And perforation is a big factor with natural convection. Here we have done extensive testing and are able to cool 95W TDP CPUs quite well. See images of the prototype for the cooling section below. Secondly: even though the case is smaller compared to the Thin-ITX platform (225 x 225mm vs 195mm x 169mm). The additional area does not translate 1:1 in cooling performance. Efficient fin height is limited and dependent on fin spacing.
  5. Absolutely we will have the VRM area cooled with the DeskMini mainboard. There is a relatively big heatsink on the fan cooled board. So that makes sense. Also the NVMe SSD on the bottom side. The one on the CPU side would be a little be more challenging.
Donut
54
35
Thank you so much for the information! I'm excited to see how this develops and looking forward to seeing the results of your testing.
Another question: Do you ship internationally (to the U.S. specifically)?
cirrus7
Cirrus7
Mar 13, 2019
25
www.cirrus7.com
Yes. We will ship the Case-only variant to the U.S. as well.
Reactions: Donut
JSItems
25
21
Hi, just wanted to say that I made an account specifically to post in this thread. I am absolutely planning to buy the 65W version of this once it comes out (I live in the US). Just bought an A300W with a 2400G and it is able to handle pretty much everything I'd need from it.
This is by no means a necessity, but if it were somehow feasible to add a VESA mount for this, that would be even better.
I will be following your progress, good luck!
cirrus7
Cirrus7
Mar 13, 2019
25
www.cirrus7.com
Sorry for the late reply and thank you for your feedback! Yes of course it will have an VESA mount option. I will update this thread soon.
Horft
Another month has passed… are there any further Information?
Can't wait to upgrade my A300! ;)
CC Ricers
2,216
2,522
I wouldn't mind using a case fan in the 10W version for more powerful APUs, only for the fact to keep the slim profile.
Reactions: Windfall
pappl
24
According to a hardware-site this Ryzen system will be on preorder (60 Euro off) and shipping will start in November, true?
I can't find any official information on the cirrus7 products website.?
My questions:
- Maximum CPU temps at full load measured with 65W case &CPU? (>20mins)
- Will it be possible to add the additional AMD Deskmini A300 modules for Wifi with big antenna mount, Rear-Audio Out (!), Extra USB-Ports...
(Bottom of page)
Rear Audio is important, i'd like a clean view without cables in the front.
-I'd be happy with a bigger case to reduce temps even more. Is it possible to add additional aluminium plates as upgrade? Is this planned?
-Is the MainBoard from the original Deskmini A300?
-Do we need to remove the original black mosfet cooler from the board?
-Any pics or better video with installed board, temps, ...?
Thanks pappl
Reactions: scatterforce
pappl
24
Got the Cirrus7 Incus 300 with Ryzen 3400G today.
First impression:
This device is well packaged, it's heavy and very well built. ?
Original Asrock Deskmini A300 accessory parts are in the package.
Installed RAM and M2-SSD. Mainboard can be removed easily to access all components.
Disassembly is well described.
Everything around the mainboard is custom made. The CPU backplate is massive/huge and is connected with an aluminium plate to the second NVMe and two SATA-drive mounts. Well designed, the creator is genius.
CPU, VRM's and SSDs are connected to the passive cooled body. ?
I'm happy, will install Linux (Manjaro) soon...
pappl
Reactions: Choidebu
scaba
First impression:
pappl
Thanks for the detailed description. This indeed sounds really good.
I assume you got the one with the biggest heatsink. How is the temps when you installing/stress testing?
Especially if you are using NVMe M.2 SSD.
Also are you going to use virtualization in your linux? Virtualbox maybe?
I am just curious if that goes well. Thanks!
pappl
24
Yes, 3400G & NVMe. I got the "Asrock A300 rear audio" kit and the "Asrock A300 USB-Kit" installed on the IO-Shield with a little tinkering.
"Manjaro KDE" installs and works fine. Not a single issue.
Fullscreen Youtube (1080p) for hours on one of two monitors gets around 45°C CPU (Linux doesn't utilize hardware decoding with chrome, so this are superb values in my opinion).
When gaming (Steam) the CPU and GPU temps are up to 85°C after a while until the "case" is soaked with heat. 85°C is hot to the touch, but no issues & i'm happy.
I guess the temperature dissipation might be a little better with more ground clearance to get more cool air in from the bottom. Will place the case on small aluminium feet. Will better match my audio receiver design too.
Windfall
2,117
1,577
Epic, would you mind taking some pictures?
