Funding CustomMOD Nano 1.6L (based on Asrock DeskMini GTX)
Choose best style of venting holes - https://imgur.com/a/3rpoc
  • Total voters
    27
  • Poll closed .
QuantumBraced
506
357
Do we have pictures of the final 1.6L design? Will it have front I/O and a rear shield?
Also, what CPU and GPU coolers will the 1.15L version support?
Reactions: AleksandarK
sergiiua
CustomMOD
Jan 11, 2017
1,098
1,969
www.custmod.com
yes we can make cutouts for ports in front. Also we can make the case according to your size.
While we are not engaged in the development of new audits of the body of the NANO.
SFF Scrub
56
What decibel level is the case emitting under full-load and intermediate load? Constant load for 3 hours max.
Looking to use this for school under 3d modeling and computation application; tired of seeing laptops all over the place, and they're still noisy as hell.
Instran0
526
107
motherboard from DeskMini GTX is almost exactly 192mm X 150mm, so if you order a case with those measurements, its too small to fit.
maybe 195mm X 155mm would work.
chinevo
SFF Recordsman
May 11, 2017
135
222
No, the size of M/B is 188mm x 147mm. M/B was tested in this case, and it fits.
