So now that the Cerberus and Cerberus-X case have been released and I've had mine for a while I was able to finally start working on it after planning out what I wanted to doing exactly. As much as I love the Cerberus-X case as it is stock, it's extremely hard for me not to want to do something different with it and make it personal to me. So with that said I planned a handful of feasible things to do with the build and case that wouldn't be forgotten about or a dead end project.
Parts List:
CPU: AMD Ryzen 1700
GPU: Radeon RX Vega 64 Limited
PSU: SIlverstone 700Watt SFX-L
RAM: 16GB (for now) G-Skill Trident Z RGB
Mother Board:MSI Gaming B350 Tomahawk Arctic
Planned Custom Parts:
To length PSU cables to free up as much space as possible.
TG side panel, with custom etching
Hardline water loop
Top secret working project
In preparation for working on the case I went ahead and shortened the front I/O Cables as they are like way too long so I would have less clutter. As well as mounting my GPU and PSU, since I already had those, once my motherboard came in to take measurements for PSU cable lengths.
For the TG side panel I was able to get some 1.5mm thick magnets that had ~2.5lbs of pull force each to mount to the steel chassis of the case. Using the joining sections where the bottom frame meets the vertical supports the magnets are held in place to keep them from sliding down, in case they weren't strong enough to hold the glass up on its own. I've went ahead and ordered some thin foam sealing tape so I can have some soft contact between the chassis and glass so they aren't just banging on each other when mounting and removing the glass. On that note the glass was also custom ordered to the dimensions of the side panel so that I know it would look right, lol.
As with everyone else I'll post updates as they happen and answer any questions anyone has. Also if anyone has any advise or suggestions I would love to hear them. Thanks guys.
Current Photo Album:
Parts List:
CPU: AMD Ryzen 1700
Hardline water loop
