Motherboard ASRock X370 Gaming-ITX/ac and AB350 Gaming-ITX/ac
Midiamp
99
49
michaeladhi.com
I'm interested to build an ITX based on this motherboard... Aside from the VRM heatsink issue, I have a question for the SATA connection. Currently I have 5 storage, 3 SSD+ 2 HDD. I'm willing to invest on M.2 SSD as the C:/boot disk. So if I use M.2, will the SATA connection free for 4 other storage? I downloaded the motherboard manual but no mention of use case restriction.
Here are the specs from the website and the same written on the manual.
- 4 x SATA3 6.0 Gb/s Connectors, support RAID (RAID 0, RAID 1 and RAID 10), NCQ, AHCI and Hot Plug
- 1 x Ultra M.2 Socket, supports M Key type 2280 M.2 SATA3 6.0 Gb/s module and M.2 PCI Express module up to Gen3 x4 (32 Gb/s) (with Ryzen Series CPU) or Gen3 x2 (16 Gb/s) (with A-Series APU)*
arth_d
You could remove the built in wifi and add a mini pcie to 2x sata card. That will give you 6 x sata and 1 x m.2
501
454
I don't see why not...
Teddy
26
47
What is important is what the chipset supports http://www.anandtech.com/show/11170...review-a-deep-dive-on-1800x-1700x-and-1700/13
Specifically the chipset features slide http://images.anandtech.com/doci/11170/AMD Ryzen 7 Press Deck-16.jpg
It should do what you want but with only x2 nvme if you choose the b350 board.
alexiseurope
Thanks for the review! Very detailed and usefull. I just received the x370 yesterday and I was debating to return it and get the AB350 but I think I will keep it just for a piece of mind for the couple better features and potentially better overclocking. Also maybe in the future the x370 boards might have better compatibility with new cpus?
But for sure the biggest point of critisism as you said is that the x370 should have more features or differences in general from the AB350.
Reactions: AleksandarK
Ares
Thanks for great and detailed review! However, you didn't touch on the topic of VRM temperatures of both boards, you say there is little difference between b350 and x370 boards for 45$ price gap, but maybe x370's VRM is much cooler? That would be a selling point for me, as I'm choosing now between Gigabyte's AB350N-Gaming wifi and ASRock Fatal1ity x370 gaming itx/ac.
7,558
Thanks guys! I plan on touching on the VRM issue in the roundup, once I've reviewed the Biostar X370GTN. This will be alongside over and undercloocking testing, so that I can show if a simple voltage drop solves or minimises the issue that people have been seeing.
That, and I'm waiting on an IR temperature gun to arrive.. :D
WanderingMendicant
47
Great review! I've got the b350 and it came with two wifi antennas. That prompted me to check out the hardware and I do indeed have the Intel AC 3168. The review seems to imply that only the x370 has dual-band wireless, but according to Intel the AC 3168 is also dual band:
https://ark.intel.com/products/94854/Intel-Dual-Band-Wireless-AC-3168
I looked at the 'package contents' on newegg and it should include '2 x ASRock WiFi 2.4/5 GHz Antennas' among other things. So if you only got one antenna with your b350, I think that was a mistake.
7,558
Have added to the article - ASRock has stated that all new batches of both boards include the better VRM heatsink - the one with the thinner thermal pad. They also ask anyone with the thinner heatsink to contact ASRock support to get the better one, at no cost!
MarcParis
Apr 1, 2016
3,777
2,918
Ahah well done @confusis..:)
Strangely I recognized your RAM settings compared to hwbot lol..:D
Stupid question from my side : how fo you check your CPU OC stability please?
5,997
4,979
That's impressive damage control, most other companies would have said:
"there can be minor differences between two manufacturing facilities, all within spec, blabla".
cough RX Vega cough
