Production Aquanaut Basic/Extreme - Ultra Low Profile CPU Block & Pump Mount Combo
flower
very interested! would like to try on my Formd T1, currently using air cooling only with a Noctua L12-S
Nouvolo
Creator
760
1,713
www.nouvolo.com
Preliminary Test - Aquanaut (v1)
Conditions
  • Pump - Barrow SPB17-S-V2, 17W
  • Radiator - 240mm ST30 v2 (multi-ports)
  • Tubing - Soft, 10/13mm
  • Other restrictions - 4x 90° angled adapter used
  • Reservoir - not used
Results:
Pump impeller cavity - no restrictions, rotates smoothly
Water block leakage - 100% dry
Flow rate (L/hr, L/min, gpm) : Noise (too loud/audible/quiet)
Edit:
Max: 228 / 3.8 / 1.00 : too loud (rate improves after clearing more air bubbles)
Mid range: 140 / 2.3 / 0.62 : audible
Lowest acceptable flow rate : 100 / 1.7 / 0.44 : quiet
Comments:
I consider the test a success in terms of quality (leakage, dimensions/fitting), and acceptable & within expectation for flow rate, considering I have added 4 angled adapters for restrictions, to better mimic real-life conditions.
Your comments and feedback welcomed. Lets have a vote if its a "Go" for this. Will prepare for small quantities if you guys confirm on this, and lets have more testing done by the SFF forum community ?.
Edit: I have 10 sets on hand at the moment. Quite a few are reserved ?
Nouvolo
Creator
760
1,713
www.nouvolo.com
Google sign up form [link]. Please fill in the form. This is for the purpose to estimate how many I need to make, and how many for each type Intel 115X vs AMD AM4.
Please only sign up if you are prepared to buy. I will send invoice based on the google form response.
SFF Community price : USD59 USD47 (20% off) + shipping*
*shipping ranges from USD15-25, depending on region
disclaimer: prices may not be final, to be confirmed
srekal34
132
127
Filled in as well(price is lower than expected btw)
Can the AM4 mounting be retrofitted in the future if I choose Intel now?
Nouvolo
Creator
760
1,713
www.nouvolo.com
The whole set of screws and accessories are different. AMD/Intel backplate use different threads, and also different mounting bracket (of course). That's why we offer them as separate.
Sure the blocks will be the same tho.
Nouvolo
Creator
760
1,713
www.nouvolo.com
Sign up rate is great, thanks for your support ?. I think we will cutoff sign up by end of this month (i.e. 31 Aug 2020), so that I can fix the quantity, and not have the sign ups keep waiting.
Note : Current batch may be slightly different from that of final launch version. But I expect very little changes except for critical issues.
Just checked shipping rate, it's gone up a bit due to covid... will be around USD20-35, depending on location. Asia > US > EU (shipping cost in general).
